Question about Edirol UA-1A (ediua1d0) Audio Input
Need driver for Edirol Audio Capture UA-1A
I have no control over my Edirol UA-1A and I cannot monitor while the device is plugged in? Any solutions?
djnick989
  • 1067 Answers
SOURCE: Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Posted on Jan 23, 2008
SOURCE: Edirol UA-4FX : No Midi output sound: OK with 1/4 plug audio/guitar in
he's wrong you need to change your wdm driver to asio 4 all!
Posted on Jul 31, 2008
SOURCE: Edirol ua-25 not detecting midi but audio works fine
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Posted on Sep 08, 2008
SOURCE: Edirol UA-25 not working on Mac OS X
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Posted on Jan 01, 2009
SOURCE: Edirol UA-1EX - hearing noise on audio playback
The UA-1EX can supply phantom power to condenser mics so the issue with the noice is a ground loop problem between the UA-1EX and your other devices (laptop/amps in the powered speekers.) I had the same problem so I found a Direct Injection box (D.I.) that allowed me to convert an stereo RCA Signal to two balanced XLR signals or vice versa. Whirlwind is the brand of mine. There should be two grouding switches on the DI that will allow you to ground the UA-1EX and get rid of the noice. Hope this helps.
Posted on May 08, 2009
Ua 101 driver won't install on windows 7 64 bit
Officially Microsoft says that 32bit drivers are not supported on a 64bit system. Check hardware manufacture for updated drivers. Good luck.
Aug 31, 2012 | Edirol UA-101 External Sound System
Can get signal from UA-25 to computer... but no audio from computer to UA-25?
Here is one solution uninstall the default driver or roll back driver. Restart your computer. When you get into windows wait for everything to load and then plug in your audio device. If you have it plugged in when windows starts then it will install a driver. In automatic updates you can select to notify of updates, but lets you install the ones you want.
Thanks for using Fixya
SAM ANDERSON
Sep 29, 2008 | Edirol UA-25 External Sound System
No power to Edirol UA-25 usb audio capture, the unit was working and now I cannot power unit. When I connect to PC I recieve a error message about a power surge has occured, could this be a fuse problem? I...
Connect it before powering system. The usual cause of no power on this is improper software configuration or assignment in the PC regarding the sound devices. It is NOT a "fuse" problem.
Make sure that when you go to "Sounds and Devices" in the control panel that the "Voice" tab is shown assigned to the UA-25. If not, make sure it is in the list of devices and assign it as default.
Jan 19, 2011 | Edirol UA-25 External Sound System
Contents of box.No instructions.
when you connect the device to the pc it will detect new hardware and you will be ready to go.
you can download the driver for your OS here:
http://www.roland.com/products/en/_support/dld.cfm?ln=en&dsp=0&iCncd=1039
Jan 19, 2009 | Edirol UA-4FX External Sound System
No solution, but I had the same issue with my old laptop, I tried everything, the only thing that worked, was to use a voltage generator, set it to 19.5 V (this was what my laptop was converting to) and getting a laptop power plug and creating a connection. Because the power pack is a SMPS, it was very noisy and this noise would be transferred to the recording.
Question of my own, where did you find drivers for Windows Vista 32 bit? I can only get my UA-1EX to run as speakers, not a recording device!!! HELP!
Submeg
Dec 10, 2008 | Edirol UA-1EX Sound Card
LC (UK).
Feb 27, 2008 | Edirol UA-25 External Sound System
UA101 and Blue Screen of Death
try this to make sure that the driver was installed correctly.:
Note: Do not use the “Add New Hardware” Wizard in the control panel. Follow the steps below to install your driver correctly.
1. Plug in the USB cable and power on the device – the New Hardware Wizard will start up (wait for it to start).
2. If Windows asks to connect to Windows Update, click on “No, not this time” and click on “Next.”
3. Select “Install from a list or specified location” and click “Next.”
4. Select “Include this location in the search” and Browse to the folder containing your driver (either on your CD or the folder you downloaded). Click “Next.”
5. Click “Continue Anyway” when the Windows Logo testing screen appears.
6. Click “Finish” when the Completing the Found New Hardware Wizard screen appears.
At this point, you may need to reboot your computer. After restarting, you should check to make sure the driver was successfully installed. Go to Control Panel / Sounds and Audio Devices and make sure your device is listed under “Sound Playback” and “Sound Recording” for audio devices and “”MIDI Music Playback” for MIDI devices. You should also check in the Device Manager to make sure your MIDI or Audio device is listed under “Sound, video and game controllers” with no problems (such as the yellow exclamation point).
If everything is successful to this point, Windows has installed the device correctly and is making it available to any software you need to run. If you can not see your device in your software, you should first try re-profiling the device (different software programs do this differently). If this does not work, you may need to uninstall and reinstall the software. If you still do not see your device, you may need to contact your software vendor for more help.
- Mac OS X -
1. Make sure the Roland/Edirol device and any non-essential USB devices are disconnected.
2. Run the *.pkg installer from the CD-ROM or downloaded driver and follow the onscreen installation instructions. When finished, reboot fully.
3. Plug in the Roland/Edirol device. Ports should now be available in software (you can verify driver availability in Applications > Utilities > Audio/MIDI Setup > MIDI Devices).
- Mac OS 9.X -
Users must first decide if they want to run OMS or FreeMIDI, which can be downloaded from the World Wide Web. OMS is recommended. See the OMS or FreeMIDI documentation for installation and activation details.
Double-click the Edirol installer and follow the onscreen installation instructions.
Note: If you continue to have problems, you may wish to consider upgrading to OS X, as its Core Audio and Core MIDI features make this operating system an excellent base for music applications.
ALSO:
Product: UA-25 UA-101 FA-66 FA-101 UA-4FX UA-1EX
Pop/click/dropout is often a buffer size problem. Be sure to check your Buffer Size setting. You'll find it in the Edirol Icon in System Preferences or in the Control Panel of a Windows machine. Increase your buffer size until the problem goes away.
There are also several settings you will want to make in order for audio applications on a Windows XP computer run optimally.
One of the more detailed websites to walk through these settings is MusicXP.net.
http://www.musicxp.net/tuning_tips.php
Dec 23, 2007 | Edirol HI-SPEED USB (USB 2.0) Audio...
Edirol UA-1A (ediua1d0) Audio Input Logo
334 people viewed this question
Top Edirol Televison & Video Experts
Electro Med Services...
Are you an Edirol Televison and Video Expert? Answer questions, earn points and help others
