Question about Polaroid FLM-3734B 37 in. LCD HDTV
When I turn on the TV it has a loud squeal for about 10 minutes until it seems to warm up.
  • 192 Answers
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my FLM 373B with 30V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Feb 11, 2010
Hyundai accent squealing very loud
You need to replace the belt.
Once a belt gets glazed it will slip no matter how tight it is.
Jan 17, 2013 | 2000 Hyundai Accent
1999 Chrysler Concorde A/C Squeal and Overheating
THE SQUEAL IS PROBABLY COMING FROM THE A/C COMPRESSOR CLUTCH IF IT IS NOT LOCKED IN WHEN THE A/C IS TURNED ON IT WILL RUB AND SQUEAL. I WOULD CHECK AND MAKE SURE YUR COOLING FANS ARE COMING ON WHEN THE CAR A/C IS TURNED ON ALSO BECAUSE THAT WILL CAUSE IT TO OVER HEAT.
Jun 26, 2012 | 1999 Chrysler Concorde
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
2002 Porsche Boxster - had squealing coming from
Mine did that off and on for a month with no other problems then it started making a loud suction noise and the check engine light came on. I took it to the dealer and they said the "oil separator" needed to be replaced.
After the repair I never heard the squealing again.
Apr 21, 2010 | 2002 Porsche Boxster
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Apr 10, 2010 | Emerson EWF2004 20" TV
Still squealing
Sounds like it could possibly be powersteering pump, provided all other pulley bearings are not producing any sound.
Jan 17, 2010 | 2006 Kia Sorento
Squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Feb 21, 2009 | Frigidaire GLER341A Electric Dryer
LG 32LCD LCD TV Problem
It turn out to be a $10 diode on the mainboard, which cost me $100 to have troubleshot and repaired
Jan 19, 2009 | LG 32LC2D Television
Loud squealing noise first 5 minutes after tv is turned on
Sounds like the color wheel. It's the only moving part in most DLP's and the bearings can go bad. If it manages to get up to speed the picture may look normal. One temporary solution may be to let it run a few minutes, then turn the set off for 10 minutes, then turn back on. When my color wheel was going bad that would often quieten it down. For the rest of the day, try to leave the set on, especially if you're only going to be away from the TV for short periods. You can turn off your cable or satellite box but leave the set on and you won't have to go through the hassle of trying to quieten down the color wheel until the next cold start. Of course the best solution is to replace the color wheel which even with a rebuilt unit won't be cheap if your warranty is expired.
Nov 02, 2008 | RCA HD61LPW165 61" Projection HDTV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
368 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
