Question about HP Scanjet 4470c Flatbed Scanner
Find doesn't work in acrobat reader (pdf) after
"search" doesn't work in acrobat reader (pdf) after scanning using Editable text OCR (HP 4470c scanner).
I think HP wants you to pay extra for that capability.
I cane gete because "Find" simply doesn't work (for me?!) in many .pdf documents after updating to the latest Acrobat (around June 2010). I solved this by installing Foxit Reader instead.
Posted on Jul 03, 2010
I have a scanned PDF document that I want to highlight and previously when the text wasn't recongnized it would ask to convert. At one point I checked the "do not ask again" box and now I am...
Basically Acrobat comes with a feature called as OCR (Optical Character Recognition) which helps acrobat in recognizing the text being used in a particular scanned document.
Just for the information, Acrobat 7 used to come with OCR accuracy of approximately 85% which has increased to 95% accuracy in the latest version of Acrobat (Acrobat X)
Now, in Acrobat 7, what you need to do is try running the OCR again on this document by following the steps mentioned below:
  • Open the document in Acrobat 7
  • Go to Document menu at the top
  • Click OCR text Recognition option under that menu
  • Then Recognize Text using OCR under that
  • This will open recognize text dialog box
  • Make sure All Pages option is selected in the new dialog box
  • Then click the edit button available in the same dialog box
  • This should open recognize text setting dialog box
  • Select Clearscan option in PDF Output Style drop down
  • Click Ok and then Ok again which should start the OCR on the open document
  • After OCR successfully completes try highlighting the text and see if you can do it
If you are still unable to do it, I would suggest you to download the trial version of Acrobat X from adobe.com which is a fully functional version which you can use for 30 days. After downloading this trial try opening the same document there and try running the OCR again and perform the highlighting of text again in Acrobat X itself.
If it still does not work please reply back with the results of the above mentioned steps and we can try performing some other workarounds to make the text recognizable.
Jun 01, 2011 | Computers & Internet
1) whether the scanned document from this multifunction hp laserjet printer be saved in PDF format. 2) whether continous scanned pages be saved as one file/document.
The answer is yes to both questions. Follow the instructions below:-
Go to Adobe Acrobat. Click on FILE. Click on CREATE PDF. Click on FROM SCANNER. Click on SCAN. You should now be scanning your first page, after completing it you will be asked if you want to scan any more pages or close. Select to scan more pages till finished. You can also select to have Acrobat do an OCR after the scan which will allow you to search the document. To do this, click on DOCUMENT, click on RECOGNISE TEXT USING OCR and click on START
May 10, 2011 | HP LaserJet M1005 Printer
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
How do you take a scanned article and transfor it to adobe reader 9 to alter document? I need to change the format i guess so it would register the material.
If you are working with a scanned document (TIFF, GIFF, etc) you must use an Optical Character Recognition (OCR) application to translate the scanned text into editable text. An application such as Omnipage will do this.
If you want a less expensive/less feature rich application try some of the trial OCR applications on ZDNET downloads at
http://downloads.zdnet.com/search.aspx?q=ocr
Nov 10, 2009 | HP Computers & Internet
My document won't give me ocr as an option for editable papers..will only scan as an image..
It's not the printer or scanner, it's the scanning software on your computer that enables OCR. Most free programs won't do OCR, You need something like the add-ons available with Adobe Acrobat.
Oct 14, 2009 | HP PSC 1410 All-In-One InkJet Printer
How to scan editable text of document.
Put the CD in the computer
Select "Add more Software"
Check if you have any OCR option
If you have one Install it
Then Try to scan from HP Solution center and select Scan Document
You will be able to Scan to Editable text
Other wise you can purchase a Software RED I.R.I.S.
and then you can directly Scan from the software to editable text.
Link for the Software :
http://www.irislink.com/c2-646-189/I-R-I-S----OCR-software-and-Document-Management-solutions.aspx
Regards Soumajit
Oct 12, 2009 | HP DeskJet F4280 All In One Printer InkJet
IS IT POSSIBLE TO SCAN TEXT TO TEXT? THANK YOU GREGG
You need a OCR (Optical Character Recognition) program to convert your scanned text pages (which are images) to text.
You printer software doesn't include such a program.
There are a number of commercial programs available -- I.R.I.S, ReadIris, Abbyy Fine Reader, Adobe Acrobat (not the free Acrobat Reader), just to mention a few -- and also some free programs (SimpleOCR came first in a Google search).
Also, some computers also come with a limited version of these programs installed. I have an HP that came with a version of Readiris
Aug 27, 2009 | HP Scanjet 4200c Flatbed Scanner
CAN NOT GET MY 5580 TO SCAN TO TEXT
Also, some computers also come with a limited version of these programs installed. I have an HP that came with a version of Readiris.
Jun 26, 2009 | HP Photosmart C5580 All-In-One InkJet...
Scanning
Did you tried with any OCR software to convert the Scanned imaged (jpeg) to Word Documen?.Always if you scan anything to an image, it will scan in JPEG format that will consume lot of memory.Scan with OCR(Optical Character Recognition) Software and that will Convert JPEG to word Document which will fix the problem.
The OCR software that i Recommend is ABBY Fine Reader.
Thanks
Riz
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Creating editable forms
To scan a document for editing purposes, you will need OCR software. What OCR stands for is optical character recognition. This software interprets the document on the flatbed for editing purposes. Reputable OCR software on the market are:
Omni Page Pro
ABBYY FineReader Pro
Presto! OCR 4.0
Pls dont forget to rate solution, thanks!!
Apr 15, 2008 | Adobe Acrobat Professional 7.0 for PC
HP Scanjet 4470c Flatbed Scanner Logo
856 people viewed this question
Seeker5211
Seeker5211
