Question about Weber Baby Q Grill
One exceedingly dirty Weber - need industrial strength cleaner
Our Weber has been used enthusiastically by two teenage boys and is FIFTHY. What industrial grade cleaner can I use to take off 2cm of burned fat?
  • 3 Answers
Take it to a portion of your yard or driveway that drains well onto your own property and can be washed down. Place the unit on the ground and saturate with any aerosol strong houshold oven cleaner bought from the supermarket. Let the unit soak for a couple of hrs. and then if you have access to a power washer just wash off all the gunk and grease. No need to hand scrub or labor over this. Let dry in the sun. and its like new. Any grease on the driveway or anything else just spray and hose off. Careful of the water spray when washing the grill as the oven cleaner is very caustic and will cause BURNS. Wear Safety Glasses!!!!!!
Posted on Feb 01, 2010
I gave my Weber Q a clean, using a BBQ spray cleaner. Since then the flames are yellow and not blue as before and the heat is insufficient to cook , and the flames go out when the lid is closed. Any...
Either the cleaner you used is partially clogging the burner holes or you inadvertently moved the air adjustment and are starving it from getting the air it needs to burn properly. Douglas
Sep 08, 2010 | Weber Q Grill
I put a heavy breather air cleaner on my 02 fat boy its fuel injected. Now around 30 to 40 mph it sputters and backfires.
If it continues to do this, you'll have to take it to the dealer and have the fuel map adjusted.
Good luck
Steve
Aug 15, 2010 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
Can't get my oil port open/off on my Fat Boy....To check it.
lightly heat the dip stick, then use a rag and longer pliers to gently but with power twist off = twist parallel to threads and be careful not to scratch. b blessed
Aug 01, 2010 | 2003 Harley Davidson FLSTFI Fat Boy
The grill is 6-7 years old.. The flames are orange and leaving sud on the food..
sound like this is insufficient air in the flame...
if you can, lift burners out, spray them with oven cleaner and leave for several minutes, use wire brush and clean them under the water. pat them dry with paper, check if all holes are free of rust, fat and debris, clean as required. this should restore your grill burners to nearly new condition, return airflow back to normal and restore your flame to blue.
wear faceshield/googles to protect your eyes and gloves to protect your hands while you do that! and better you do not wear your sunday best either... oven cleaner is strongly caustic and can burn holes in the fabric and bleach it.
if you find this advice helpful, please do not hesitate to leave comment and give me your vote4, thanx!
Jul 28, 2010 | Weber Summit Gold B (NG)
Oil come out the air cleaner
Too much crankcase pressure or the breather pipe is split/dosconnected. The crankcase breather goes into the rear of the air filter and the crankcase gasses are drawn in to the cylinder with the gas/air mixture and burned
Nov 20, 2008 | 2003 Harley Davidson FLSTFI Fat Boy
Nov 10, 2008 | 2001 Harley Davidson FLHRCI Road King...
Weber Baby Q Grill Logo
128 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
