Question about ICOM Informatique BP-85S, ICOM,IC-W2A,IC-2SRA,IC-4SRA,IC-2SAT,IC-3SAT,IC-4SAT,IC-24AT,IC-RI,IC-X2A, 12v 1100mAh NiCd ... 2-Way Radio
My batteries are all old and dead and I got the 2sra unit out and plugged it into the desk charger to try and see if it would still go. It did for aa minute or two and then has never gone again. Recently I decided that it was no use as is and carefully diassembled it and found that the 3volt memory battery was dead. Today I replaced it and then reassembled the unit, but it is still playing dead. I checked the voltage out of the desk charger with just the dead battery inserted and found 23volts accross the terminals that connect to the tranceiver and so I think i may have killed it. I did heare that there was a sequence of buttons that would reset the logic for this unit, but haven't been able to find anything. I have almost every accessary that was made for the 2sra and would like to get it going if possble. regards Peter Jackson peter.cheryl.jackson@gmail.com
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Apr 20, 2015 | Olympus Camedia Cameras
Tip
Travelers should use cameras with AA Batteries
Digital cameras come in two varieties: those that use AA-size batteries and those that are powered by proprietary lithium-ion batteries. If you are a traveler, particularly someone who enjoys remote or rustic locations, choose a camera with AA batteries.
When a camera that uses proprietary batteries runs out of power, you have no choice but to plug the battery into a power outlet to recharge it. This requires an available outlet, a battery charger, and, if you're in a foreign country, a power converter. If access to an outlet is ever in doubt, or if you don't want the hassle of carrying cords and chargers, then the limitations of this system are obvious.
When a camera that uses AA-size batteries runs out of power on a trip, you can simply throw out the old batteries and drop in a new set of high-performance AAs like the Energizer E2 Lithium line. Two or three sets of such batteries can usually take you through a 10-day trip. If you're out of high-performance batteries, you also have the option of using standard alkaline batteries, which are available anywhere in the world, and make a cheap and convenient source of backup power (though they only offer a fraction of the life of high performance batteries).
Recent trips to Asia and Africa have borne this theory out—after my companions' cameras had been sidelined by dead batteries, I was still happily shooting away with my AA-powered Canon PowerShot.
on Jun 07, 2010 | Cameras
Tip
Digital cameras
Travelers should use cameras with AA Batteries Digital cameras come in two varieties: those that use AA-size batteries and those that are powered by proprietary lithium-ion batteries. If you are a traveler, particularly someone who enjoys remote or rustic locations, choose a camera with AA batteries.
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Why the battery charger blinks during charging
If these are old batteries, one or more may be dead.
Jul 18, 2010 | Duracell AA/AAA NiMH Battery Charger with...
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
When i turn on my camera it will not extend or let me set the men
Check batery type suitble for your camera, also ensure correctly installed(+ -) Check contacts are clean
Sep 24, 2009 | Fuji FinePix A360 Digital Camera
Motorola talkabout t5700
No, the charger is only usable to charge the rechargeable NiMH or Li-Ion battery which comes with the radio. Attempting to charge Alkaline rechargeable batteries with this charger could cause the to expode. If your charger is not charging the batteries which came with the units, it could be you do not have the charger cord end plugged in all the way, or the batteries dropped below the initial charge level by setting on a store shelf too long. Most TalkAbouts come with a cradle style charger to hold the radio, and a possible plug to plug into the charge hole. Check all connections, and clean any battery/charger contacts with a pencil eraser. To re-initialize the batteries you would need to attempt 3-5 charge cycles by charging for 8-10 hours, then letting the battery rest for 8-10 hours, repeating 3-5 times as needed. If this does not bring the battery back to life, you need to replace the batteries.
Jun 07, 2009 | Motorola Talkabout T5700 AA (22 Channels)...
Cant charge battery pack for wii fit balance board
You may want to send an email to customer.services@gem.co.uk. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
Jan 27, 2009 | Nintendo Rechargeable Battery Pack 3600mAH...
Battery
There is no rechargeable internal battery, AA only.
Nov 21, 2007 | Garmin StreetPilot i3 GPS Receiver
Radio Communications Logo
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
BJ Russell
Steve
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
