Question about Kenmore Elite HE4 Electric Dryer
I have the Kenmore Elite HE4 Smart heat Quiet Pak9 model 110.C85862400 and my problem is that it takes 90 minutes to dry a set of flannel twin size sheets and 2 hours to dry about 8 towels, heat works, cut out works, vent clean and newly installed as requested by a Sears repairman, washer is supposedly working and spinning clothes dry. Sears repairman was in yesterday and said everything is fine and it is suppose to take that long to dry. Not sure what my next step should be... I bought energy efficient because it was suppose to dry things in 30 minutes or around that time any suggestions would be greatly appreciate as a different sears repairman is coming in next week... 10th one in 3 years.
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Posted on Aug 04, 2007
revamos
  • 16 Answers
SOURCE: do you have an idea
the most common problem 90% of service call blocked vent dirty or crushed behind in wall also may have blockage if not a thermo stat is bad
Posted on Apr 19, 2008
  • 97 Answers
SOURCE: No heat...replaced vent hose...still no
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help.
Posted on Jul 12, 2009
  • 1129 Answers
SOURCE: my dryer takes forever to dry clothes. A typical
Wrong valve or defective unit
Posted on Jul 15, 2009
My Kenmore elite smart heat quiet pak 4 automatic dryer model 110. 87872603 shut off during drying cycle and showed service code f23. The dryer was extremely hot.
call sears service . sounds like the exhaust blower has failed you or perhaps the filter us plugged and needs cleaned out which should be done before or after each use
Jun 16, 2015 | Kenmore Dryers
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
The air drying the clothes is cold, not hot. We have a Kenmore Elite Electric Dryer, Model 110 63952100
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Kenmore Elite HE4 Electric Dryer
No tension on the tension pulley.
Check that the slide/rod /bracket is not jammed on the adjusting mechanism.
Jan 18, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
235 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
