Question about Panasonic Workio DP-2310 All-In-One Laser Printer
Error message Yes i currently have a dp-2310 and the error message reads EO4-01 and have checked the bottom roller and other compartments for a paper jam but have no luck locating any. I even went as far as taking of the bottm rollers parts to have a better look inside the machine but didn't see any paper jam. Appreciate your assistance for further advise on the solution.
  • gaviles Feb 19, 2008
    Hi IB4G2008 where and how would i reset for default on the printer??
    i turned off the printer waited 30 seconds for clearing memory and then turned back on waited for main menu to come up but can't find the reset for default button? how do i do this to recycle the power??
  • 33 Answers
Means it has over or under heated, needs to be reset in srvice mode-lpb fuser reset before it will work, then may need lamp or thermostat.
Posted on Mar 05, 2008
    Genius:
  • 3,587 Answers
Shut down printer..wait 30 seconds for on board memory to clear..restart..go to menu, reset for default..recycle power, see how that works.
you may need new drivers, though..
Posted on Feb 18, 2008
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
May 07, 2010 | Panasonic DP-C213 Color Copier
Getting error j43 on workio 190, but there is no paper jam
yep
it is common error for dp-180/190.
and the usual cause of that are worn out 2 bushings of heat roller
what you can do with that is to clean the fuser unit esp. the bushings of heat roller.
well off course the safest way is to replace the whole fusing unit.
that's it. :)
Feb 08, 2010 | Panasonic Workio DP-190 Multifunction...
17H Service Required
Please follow the solution in the link below. Also as you putting in the cartridge always check for loose toner in the area and on the cartridge itself as this can block the sensors.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=74,E=0000000001343666831,K=8485,Sxi=0,Case=obj(3510)
Niallbt
Mar 29, 2009 | Xerox Phaser™ 6115MFP/D All-In-One Printer
Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Mar 27, 2009 | Panasonic Workio DP-2000P Copier
HP 1000 Laser Jet Printer - error printing
Turn the printer off and then back on. Does it go to the ready state? or does it come up and error? If the error only comes up when asking the printer to print then the printer probably has a worn paper pickup roller. You can take the old roller out and rotate the rubber tyre a little.
Mar 26, 2009 | HP LaserJet 1000 Printer
Error message -no loop current
It can't find a DIAL TONE check the line with a regular phone.
Mar 06, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Panasonic DP 2310 E04-01 error
Hi. it's had a fuser over heat, will have to be reset after checking all paper is removed from fuser.
Feb 25, 2009 | Panasonic FP-D605S2 Copier
My Dp-180 has an error J01
there is a tab at the back of the tray , make sure it is pinched up to the paper.. and take all the paper out and see if there is any folded paper at the bottom it not.. msg me directly and we can try one more thing
Dec 23, 2008 | Panasonic WORKiO DP-6030 All-In-One Laser...
Panasonic Workio DP-2310 All-In-One Laser Printer Logo
212 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
