Question about General Refrigerators
I have a General ER - 34 JW(W) Fridge and I need to know the wattage of the fridge
  • 90 Answers
Hi
This Fridge uses 668 KW/H/ Yr. as per Energyguide US gov. tests.
This come to 80 Watts per Hr.
Regards
Berry
Posted on Feb 01, 2010
Want to start fridge with generater what wattage do I need to start
find the decal on the fridge( side , back inside ) that has the specifications on it
it will show wattage usage for the motor , volts required and phase/cycle requirement
now for example --if the wattage is 750 watts , then the start up wattage will be almost double for a few seconds until the motor builds up speed
so the generator size will be 2000watts continuous
that is an example
however understand this , if you get a genset that just covers the watts required , it will use a lot more fuel under full load than a gen set that has a capacity of say 4 times the requirement
next point-- gensets that just do the job will struggle on compressor start up and that can cause problems on modern fridges power boards where as a larger genset will hardly notice the load of a starting compressor
Lastly always use a surge protection board before the fridge lead as gen sets can "hunt " and produce power surges which can damage a board of the fridge
In reality if you have an outage,-- mostly at night,-- I would consider a gen set of 6500 watts capacity as that will handle fridge , freezer and house lights
I run a scorpion 6.5 kw get set connected to the house by a three way switch and a caravan plug in the meter board and that runs 2 fridges , freezer , lights and one small plate on the electric stove and 20 liter fuel tank lasts up to 6 hours running
and no it is not an inverter type so the cost of the unit is around $1200.00 aud compared to an inverter type which is more than double that price
plenty of food for thought so that you make an informed decision
Aug 21, 2016 | Refrigerators
Why does my fridge g frm preset 34 degrees to 58 degrees for a few hours and then back to 34 degrees for a few hours and back and forth?
all fridge thermostats have a 10 - 15 degree differential between the cut in and cut out temperatures, your is exceptionally large hence needs to be replaced
Sep 12, 2014 | Refrigerators
Can i plug a mini fridge into a surge protector?
you must check the amper ( current) rating as will as wattage of the mini fridge usually at the back portion. if the current and wattage rating of the surge protector is higher capacity so it can hold this fridge.
Oct 02, 2012 | Emerson White Compact Fridge - 1.8 Cu. Ft
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Feb 08, 2009 | General Electric GFSS6KKXSS Stainless...
Freezer and Fridge at wrong temperture
How old is this fridge? Your themostat may be shot. Put an accurate thermometer in the freezer and cooler to ge the real reading. If they are the same as on the door then the themostat is probably the problem. If not, it could be that all you need is a new display.
Dec 17, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Kenmore elite refrigerator error code er if
Bad icemaker fan. When looking in the freezer, its the one on the left.
Sep 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
142 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Shehu Pro
Shehu Pro
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
