When I turn on unit...it flashes the Phoenix BIOS screen and then says "Enter Password" (wants me to enter the BIOS password)...dont know it...HELP!! Don 903-520-6137
  • 16 more comments
  • stockbucks Feb 01, 2010
    A Laptop technician/repairman has already taken the cmos battery (unsoldered it...and soldered it back on) off the motherboard and back on...most of the default passwords u gave me i've already tried...i tried them all...why do I need to try in 30 min intervals? With other Password issues I've never had to wait...just wondering...do u have any other suggestions?
    Anymore ideas on this BIOS password problem
    Also I have a Phoenix BIOS...I think the default passwords you gave me were for an AWARD BIOS...thot u should know...let me know.
    Yes it is a laptop....Toshiba Satellite A105-S2051...thx
    This is for Toshiba Laptop...I have already removed the CMOS battery on the laptop...did not erase the BIOS password tho...pls reply..thx
    where is jumper to clear BIOSsettings to clear/remove jumper? Do I have to take laptop apart again (my friend already did when he removed the CMOS battery which didnt fix it).
  • stockbucks Feb 02, 2010
    r u talking about 'clear bios password' jumpers on Toshiba laptop motherboard?
    I will consider...my tech friend has already had laptop apart when he removed CMOS battery..but didn't notice any jumpers to change temporarily...I dont think i want him to take it apart again without 100% sure that this would eliminate BIOS password!
    Ok deal...I will try and call Toshiba sercie center tomorrow and see if they will fix it for me unde warranty....I will let u know...and THX again! Don
    already tried this...didnt work...thx
    Just found out...Bad Motherboard...thx anyway
    it is bad MBoard..thx anyway
    "wayneard"...your co-worker... figured it out...Bad MBd...fyi...thx
    You gave me the idea to call Toshiba Service provider..so I did...they said MBd is bad...they will fix it under warranty...so thank you...send me another inquiry and i will 'Acept This Solution', so you will get credit...THX!
    Yes of course...'wayneard' helped me solve it...bad Mbd...thx Wayneard
    President:
  • 1,901 Answers
Hello Don.
You need to shut it down and remove the power cord. Press and hold the power ON button for about 5 seconds.
Open the case to the computer and do one of 2 things:
1) Pop out the CMOS battery which is about the size of a quarter and is usually a 3 volt battery. Leave it out for several minutes, then reinsert it in the slot. Close the case and connect the power cord. Power up and then you will have to enter the BIOS, verify your settings and do a Save and Exit. This will eliminate the password prompt.
OR...
2) Most motherboards have a jumper labeled CLR or RESET. There are 3 pins together with a jumper on 2 of them. If the jumper is on pins 1 and 2, remove it and place it on pins 2 and 3 for 15 seconds. Then remove it and place it back on pins 1 and 2. Replace the cover, power up and again, enter the BIOS and verify your settings and do a Save and Exit.
Note that this is for desktop PC's. If you have a laptop or have trouble opening the case, please post your computer's make and complete model number, and i will try to be more specific.
Thanks for using Fixya.
PS. We are not supposed to contact you via email or telephone. Hope you understand.
Wayne
Posted on Feb 01, 2010
  • 2 more comments
  • Wayne Mineard
    Wayne Mineard Feb 01, 2010
    What is the make and full model number of the system?
  • Wayne Mineard
    Wayne Mineard Feb 02, 2010
    I know you may not want to hear this but this is directly from the Toshiba site:
    Both the BIOS and Supervisor password prompts appear immediately after the computer is started or restarted, or taken out of Standby mode. Once a BIOS or Supervisor password is set, the computer will only start Windows (or any other operating system) after that password is entered correctly.
    Entering either a BIOS password or a Supervisor password permit normal use of the computer. The difference between them is that if the Supervisor password is set, it must be entered in order to change system settings. Exactly which settings require the Supervisor password permission varies from model to model. Knowing the Supervisor password makes it possible to change the BIOS password, without knowing it.
    The BIOS and Supervisor passwords cannot be removed or changed unless you know the existing password(s). If you forget your BIOS or Supervisor password, you will have to have the password removed by a Toshiba Authorized Service Provider. Although the prompts for these two passwords have the same appearance, the passwords are set and removed differently. If both are set, the Supervisor password takes precedence.
    There is also a know problem with Toshiba laptops that addresses older BIOS giving the prompt without the user setting up a password. If this is the case Toshiba has agreed to make a repair at no cost through 12/31/10.
    See this page:
    Toshiba Support Bulletins
    Click on the one that says Incorrect power-on password prompt...
    Sorry I can't be of more help.
  • Wayne Mineard
    Just for my sake, how did you determine the MB is bad? (If you don't mind me asking...for future reference.)
  • Wayne Mineard
    Wayne Mineard Feb 03, 2010
    Good deal!
    Thanks!
    Wayne
    Genius:
  • 1,341 Answers
Open the pc, access its motherboard and remove the bios battery for a while, say 12 hours and put it back.This normally resets bios password.Hope this helps.
Posted on Feb 02, 2010
  • heeman mohun Feb 02, 2010
    If it is a laptop and is still under warranty then do not mess with it further as it will void the warranty.Contact the manufacturer to solve this issue.
  • 542 Answers
This is due to you have selected the boot on password option enabled in the BIOS level. But you have forgotten the BIOS password, then need to reset the BIOS setting by changing the jumper settings on the motherboard (to clear CMOS setting)which is near the CMOS Battery.
Or try to remove the CMOS battery and switch on the system, it will ask to do the settings once again.
Revert back for more assistance.
  • 3 more comments
  • Rajesh Pai
    Rajesh Pai Feb 01, 2010
    Have you tried to change the jumper settings to clear CMOS option?
  • Rajesh Pai
    After changing the jumper setting, need to start the laptop and switch off your laptop will clear the passwords.
  • Rajesh Pai
    Jumper setting is there near the CMOS battery and if the jumper already set to 1st and 2nd pin, change it to 2 & 3 pin. After start & switch off the laptop, revert the jumper settings.
  • Rajesh Pai
    Rajesh Pai Feb 02, 2010
    This sould work,..I mean to say is that, you have not properly changed the jumper settings. If you have changed the jumper settings properly, then it will reset all the settings including BIOS password. Try once again and revert back for more assistance.
  • Rajesh Pai
    Provide you feedback and rating on the same.
  • 838 Answers
Hi, Welcome to Fixya.
Did you try removing the battery from motherboard?
Also try clearing the CMOS but remove & replace jumpers.
Please let me know the result.
Thanks & Regards
  • 2 more comments
  • Mohd. Tareq
    Mohd. Tareq Feb 01, 2010
    You can try the default passwords in 30 mins interval.
    • AMI
    • Award
    • bios
    • setup
    • cmos
    • AMI_SW (case sensitive)
    • AMI!SW/
    • AMI?SW/
    • j262
    Thanks
  • Mohd. Tareq
    I just added this password to check defaultly. And I added 30 mins interval to save the bios memory from being corrupted/crashed or for to save from blockage issue.
    As you rated my answer the question is opened to other experts.
    Hope you will get the solution.
    If you think I can help you in any field please go to my profile and click Ask me.
    Thanks for joining us.
    Have a nice day.
  • Mohd. Tareq
    Mohd. Tareq Feb 02, 2010
    There should be a jumper or block of jumpers where it's written clear bios password.
    Can you check it. because as your details it's looking like that.
    Thanks.
  • Mohd. Tareq
    Yes , Exactly.
How do i unlock phoenix bios passsword laptop is locked
Phoenix BIOS backdoor password. Try ine of these?
BIOS
CMOS
phoenix
PHOENIX
Nov 06, 2012 | Computers & Internet
Dell phoenix rom bio plus version1.10a05 in the bios screen displays enter password need next steps
Found these backdoor passwords online. BIOS - CMOS - phoenix - PHOENIX. Let me know if any actually works.
Clearing passwords via jumpers.
http://support.dell.com/support/edocs/systems/opgx520/en/ug/advfeat0.htm#wp1117484
Oct 12, 2012 | Dell OptiPlex GX520 PC Desktop
Acer aspire 2920 bios password removing
The password to by-pass bios password are these, hope they will hope you, once you enter BIOS using these passwords you can reset it to normal
Phoenix Backdoor BIOS Passwords:
  • BIOS
  • CMOS
  • phoenix
  • PHOENIX
Mar 18, 2010 | Acer Aspire 4720 Notebook
BIOS password
If you have a Phoenix BIOS (what it is most probably) try a backdoor password.
Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Aug 29, 2009 | Computers & Internet
Phoenix bios password
The thing is that somebody set bios password. On phoenix bios based on intel platform? like yours normally if you will enter bios password incorrectly 3 times bios will lock the computer and it will generate 12 digit lock code. You will need to contact Toshiba technical support to get bios unlock password. (Normally this is generated by them within couple of hours.)
I would recommend you to check with toshiba support before locking bios (entering password incorrectly 3 times)
May 28, 2009 | HP Pavilion dv1000 Notebook
Phoenix password
Try these...
Mar 19, 2009 | Toshiba Satellite A135-S2276 Notebook
Ibm thinkpad r51
What is the default password for my R51 Thinkpad by IBM Model # 2888?
Feb 04, 2009 | IBM ThinkPad R51 Notebook
Acer aspire 5315 wont boot up
for password, you need to reset your bios. check your bios and enter the password given below:
for AMI BIOS Passwords:
A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
for AWARD BIOS
01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
BIOSTAR
CONCAT
CONDO
Condo
d8on
djonet
HLT
for Phoenix
BIOS
CMOS
phoenix
PHOENIX
Other Manufacturer BIOS Password
Biostar - Biostar
Compaq - Compaq
Dell - Dell
Enox - xo11nE
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
VOBIS & IBM - merlin
hope this helps!
Nov 12, 2008 | Acer Aspire 5315 Notebook
Her
At boot-up note the BIOS provider (Award, AMI, Phoenix, IBM, etc.)
For Award BIOS’ try these backdoor passwords:
AWARD_SW
j262
HLT
SER
SKY_FOX
BIOSTAR
ALFAROME
Lkwpeter
j256
AWARD?SW
LKWPETER
syxz
ALLy
589589
589721
awkward
CONCAT
d8on
CONDO
j64
szyx
For AMI BIOS’ try these backdoor passwords:
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
A.M.I.
CONDO
For PHOENIX BIOS’ try this backdoor password:
phoenix
Jul 12, 2008 | Computers & Internet
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
