Question about Refrigerators
Refrigerator not getting cold over last several days. The bottom of it gets full of water. I took the rear plate of of inside the freezer, fan is working, compressor is blowing & it didnt seem like the vent was clogged or frozen. I cleaned all of the ice from teh bottom of the freezer jsut to be sure. Whats next?
  • 90 Answers
Hi !
Very simple... the Gas has definitely leaked...
Get it fixed ASAP as the compressor will burn out by over running.
Regards
Berry
Posted on Feb 01, 2010
Ge Gsh25jsxnss side x side fridge is not getting cold, took plate off & damper works fine, I don't see ne kind of fan, it goes straight 2 the freezer near the ice maker. freezer is cold & working fine
Evaporator fan motor has probably failed. p/n WR60X10185
It is located in the freezer section, behind the back panels inside, and under the icemaker. Remove the screws on the bottom panel in the freezer, remove the ice maker, auger motor, and panel. is is about center of the freezer.
Jun 22, 2016 | GE Refrigerators
Freezer works fridge does not
Needs to be completely thawed for 2 days. Or wlse the circulator fan under the freezer panel inside freezer is not working. Take the plastic bottom of freezer out and let thaw. Then plug in fridge and check if the fan is running inside there. Do not poke around inside there or fridge will be punctured and ruined.
Jan 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
The freezer side is working but no cold temperature in the fridge section of our side by side door with water and ice dispenser kitchaid fridge. Wonder what the problem is?
Hi
If the refrigerator is in defrosting mode, the freezer compartment temperature will be less cold than usual. Wait 20 minutes, and you should be able to feel cold air blowing in the bottom of the compartment. If you have frost on the freezer coil, you probably have a defrost problem. Your freezer should go into a defrost cycle about twice a day. When this happens the compressor and fans shut off and a defrost heater in the freezer coil will turn on heating away the ice. This usually last 10 - 20 minutes. If the defrost coil doesn't defrost it will become a solid block of ice and this will in turn block the air from blowing into your refrigerator compartment. There are several things that can go wrong with the defrost cycle such as the defrost timer, defrost heater, or the defrost termination thermostat.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 19, 2010 | KitchenAid Refrigerators
Refrigerator section not getting cold - air vents not blocked - cold air coming into freezer but not out of vent at top/rear of fridge
Evaporator fan may not be running. This fan distributes cold air throughout the freezer and to the refrigerator. The fan is likely located behind an access plate at the top of the freezer. If it's running, you should be able to hear it. If you can't hear it, open the access plate and look at it. If it's not turning, you will likely have to replace the fan motor.
Oct 20, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Water always inside refrigerator sometimes ice forms
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Dec 05, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
