I bought a Konica 7145 and I have several problems. When I turned the copier on for the first time I got an error F-26-3. I figured this was caused by the fact that I was transporting the copier lying down. So I removed the developing unit and the drum to clean it. I cleaned both everywhere besides the green drum itself and the magnetic roller on the developing unit (even removed the sensor in the back and cleaned it there). After inserting both thing back in the printer and starting it on again I still get the F-26-3 code. However, I am able to get around it by doing the following "Pressing 36 while powering up, selecting process adjust, select L detec, start". After I do that I click on "Running Mode" and select Running Mode 1. When I enter into the copy mode I sometimes get the error F-26-3 again (have to redo the steps again) and sometimes not and I am able to start the copying process. Well, the second problem is that in cases when I can start the copying processes I get paper jams all the time, in different places. It usually takes 2 pages at the same time from paper trays and jams right by the upper tray (or right next to the tray I am using), if I insert a page into the bypass tray the paper may be misfeed without it even entering the printer or it gets stuck by the "Finisher Conveyance Unit". Pages coming from the trays (if they don't jam anywhere else) get stuck here as well. Basically the entire page enters this area (curls up) without being forwarded further. When I observe the copying process I don't see the white plastic gears moving just to the left of the "finisher conveyance unit" which may indicate why the paper is not passed through this part. The interesting thing is that pages that jam in this area do not have any print on them, they are basically clean. When I first opened this area (after I got the copy machine) there were a few pages stuck here and they all had print on them. This was right before I started removing and cleaning the developing unit and drum. I would be extremely grateful if someone could help me with those issues. I used to work (clean/repair) Xerox copiers in the 90's so handy work with these machines shouldn't be a problem for me.
  • eurosears Feb 01, 2010
    I wanted to also mention the fact that people who sold me the printer told me that they were able to make copies without a problem. Basically everything worked. However, when they were moving the copier they didn't settle it gently on the floor but rather dropped it down and once they turn it on that's when the jam problem began occurring.
  • 1456 Answers
SOURCE: When I try to print, I get a consistent jam in the
Hello
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very thoroughly eyeball the paper path for any "foreign" objects.
THANK YOU FOR VISITING FIXYA
Posted on Feb 10, 2011
checkitright
  • 1362 Answers
SOURCE: misfeed in finisher
finisher is the unit attached to the copier on the left.
open door and look for any green handle, these are what you need to move to locate the jams
Posted on Oct 20, 2008
  • 87 Answers
just check propely any small piece of paper is in machine or any sensor in paper path is disturbed check all sensors and there levers .or take a hard file cover and from bypass with ur hand pull it in copier and send him to toward exit tray .just off copier first and do this .
Posted on Dec 16, 2008
  • 1297 Answers
SOURCE: Ricoh Aficio 250, clear misfeeds at w and finisher
Clean the sensors in this parts and try reset the SC codes:Enter in the SP mode press 5-810 (SC code reset)select 1.Then hold down the Photo mode key and the +key at the same time for at least 4 sec.
Posted on Sep 26, 2009
  • 158 Answers
SOURCE: I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Posted on Oct 15, 2009
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
I need a solution for konica 7145 error code 26-3
F26-3: TDS (Toner density sensor output abnormality) Abnormal output from TDS (Toner density sensor) TDS output ripple voltage failed to reach 0.5V
Possible that developer needs to be replaced or Toner is not supplying into the developer Unit.
Service Manual available to your model at: http://fixmfp.com/index.php?route=product/product&path=60&product_id=52
Sep 06, 2013 | Office Equipment & Supplies
My konica minolta bizhub 7145 b/w copier is showing error code F-51-5 The copier will power up and then seize. The copier is about 5 years old with a total count of 320,000 copies
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
I have a Konica 7145. It has error code
This is a fixing unit over temperature fault. The device has detcted the fixing unit has gone over 470 degrees F.
You will need to check the Thermisters in the fixing unit, and repair or replace as needed.
Service mode DIP Switch needs to be reset after repairing.
WARNING
• When F34-∗∗, F35-∗∗ or F36-∗∗ (fixing temperature related abnormality) occurs, be sure to repair a defective part before setting the 25 DIPSW 3-1 to 0.
If the 25 DIPSW 3-1 is set to 0 without repairing a defective part, it may cause a fire.
Apr 26, 2010 | Canon imageRUNNER C3200 Copier
Error code F-35-1 in bizhub 7145 copier
quote is probably in the right price range. you need to look at how many copies are on your machine. look at any future repairs/supplies that will be needed. like drum, developer unit. If these are also needing to be changed soon, you will have to plan on those costs also. Any comparable machine that you get get will be expensive to repair the big items. You have to put all of the money that you spent on the machine and find out how many copies you have made. you can then figure out the cost per copy. At the same time, if this machine does everything that you need from a copier, do you want to buy a new one at much higher cost.
Oct 13, 2009 | Toshiba E-Studio 3511 Color Copier
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
Oct 29, 2008 | Office Equipment & Supplies
Error code f35-6 on konica 7145 copier
Replace Thermo- fuse (open ) fuser not getting to 160, and clean thermister, toner builds up between roller and thermister causing overheating of fuse to blow .
Apr 25, 2008 | Office Equipment & Supplies
Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Jan 12, 2008 | Canon imageRUNNER 400S Copier
213 people viewed this question
k24674
jasbo
jasbo
