Question about RCA P52921 52" Rear Projection Television
The convergence adjustment option in the screen menu does NOT appear. therefore i can not adjust my tv, which is out of convergence
  • RCA Master
  • 5,807 Answers
it could also be caused by these
http://cgi.ebay.com/Original-RCA-FL231-Convergence-Fuse-259213-------ITC222_W0QQitemZ140374724954QQcmdZViewItemQQimsxZ20100116?IMSfp=TL100116231008r24715
you may need also to check these out
Note: It is connected on pin 11 of flyback, if it the microfuse is open
( meaning no resistance ) you may need to replace them, see the
image above .
it can also be cthe convergence adjustment option in the screen - ec7307a.jpgese diode
available @
http://servicemanuals.vstore.ca/product_info.php/pName/dl231-diode
include the capacitor too, CL230 ( 100 uF / 50 V )
if you need the full kit , here is the link
http://servicemanuals.vstore.ca/product_info.php/pName/rca-itc222-convergence-option-missithe convergence adjustment option in the screen - d51f624.jpgit
these are tthe convergence adjustment option in the screen - 33c3c92.jpg of the FL231
you may need to clean the board with an air compressor or just
an ordinary paint brush to see the fuse.
Thank you for choosing FixYa for assistance. I hope that my
information proves useful to you. If so, please take a moment
to provide me with a positive rating. I'd really appreciate it.
Regards,
palaboy
Posted on Feb 01, 2010
  • Rommel Cana
    Rommel Cana Feb 01, 2010
    if that is not the board you are having, then maybe these one will do.
    PTK 195 Convergence Kit
    Have the professionals do it for you, thanks again for using Fixya!
  • Rommel Cana
    Rommel Cana Feb 05, 2010
    have a look also if these is like the one you are having
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
It appears to be convergence issues. Red, green,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
How do you set convergence
What is your Make and Model number?
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Need to adjust convergence
this is a very nice tv very strong, but you have a problem on the convergence circuit or more likely on the power circuit for the convergence and this is the reason why the main processor it doesn't recognize this circuit. it need service not a mayor problem.
Nov 25, 2008 | RCA P52926 52" Rear Projection Television
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
RCA P52921 52" Rear Projection Television Logo
311 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
