Question about HP Officejet Pro L7680 All-In-One Printer
Ink compartment door latch is broken. Don't know why or how other than 1/2 (one side) of latch pin seems to be gone. Why would HP make something so easily broken? Can it be fixed? What do I do? - Allen
I had the same problem and now I keep the door closed with VELCRO, the doubleside hooks that are used to close also clothing.
Posted on Feb 07, 2010
Testimonial: "Thanks - Velcro is probably the way I will end up. Right now I've got painter's blue tape on it. Does anyone know if the door can be replaced?"
I have an Oster DLC-7 food processor. It has always been very hard to close requiring force. The last time I used it, a white plastic part popped off from the back. I don't know whether anything is...
You have a broken the door latch.Most people have the habit of slamming the door shut ( the same way some people hit the enter button on the computer ).With age the plastic becomes brittle and the slamming accelerates its demise. Now connected to this latch is a safety feature which shuts down the Microwave when the door is opened during cooking. So till you replace this latch the microwave will not work. Disconnect the microwave from the power outlet and remove the top cover ( 4 to 5 screws at the back ) , look near the bottom close to the DOOR OPEN button.You will see the rest of the latch with a spring attached to it.Do not attempt to glue the broken piece because the force exerted on the latch is very high and will not hold. You challenge is getting a replacement. Best would be to contact the seller or locate a authorized service center from where you might be able to procure it. It should cost you about 5$.
Aug 22, 2011 | Microwave Ovens
Where do i get a new Ink compartment door ,my latch is broken?
Call HP parts depot at this number and they'll walk you through it.
1-800-227-8164
Referencing the link below where that phone# came from may also be useful for you.
Regards,
The Selkie
Sep 28, 2010 | HP Officejet Pro L7680 All-In-One Printer
I can't open to fill tank.
Hehe, seem your spring pins is gone...
when you press the handle, normally it release the thank
and it is lift by a little plastic square attached to a spring...
it is probably broken...
push the handle and lift with a knife...
May 01, 2010 | iRobot 5800 Scooba Vacuum
Driver side door will not close may be a broken bolt how do i fix this
Seems as though your door latch may have closed without having the door closed.
1. Use a screw driver of any kind to simulate the door latch pin. Stick this into the latch and put a small amount of tension on the latch pulling it to the inside of the car and actuate the door handle.
What you are trying to do is get the latch to move to it open door position. It might help to look at one of the other doors latches with the door open so you can better see this demonstrated and compare with your malfunctioning door.
If this all works out - make sure you take the time to lubricate the door latch assembly to prevent future problems of this sort..
Jan 29, 2010 | 1997 Chevrolet Monte Carlo
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I need to remove/replace cartridge,i dont know how?
Hi!
This link guides you on how to replace the cartridge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&product=79477
  1. Turn on the power.
  2. Lift the print carriage access door on the front of the unit, just above the output tray. The print carriage will move into the middle of the access area. Figure 1: Raising the front access doorc00004385.jpg
  3. Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch and then pulling the lower section of the latch forward. Lift the latch.
  4. Grasp the sides of the ink cartridge and pull the cartridge out to remove it. Figure 2: Removing the cartridgec00004386.jpg
  5. Remove the replacement cartridge from its packaging. Touching only the black plastic, remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tapec00004387.jpg
  6. Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage as shown below. Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch). To install the optional photo cartridge (HP 58) for six-ink photo printing, remove the black print cartridge (HP 56) and insert the photo cartridge (HP 58) instead. Figure 4: Inserting the cartridgec00004388.jpg
  7. Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur. Figure 5: Latching the ink cartridges in placec00004389.jpg
  8. Close the print cartridge access door. Figure 6: Closing the access doorc00004390.jpg
  9. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Nov 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
HP Officejet Pro L7680 All-In-One Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
