Question about Sharp FO-4400 Fax
I WANT TO SEND THE SAME FAX TO SEVERAL NUMBERS
  • 583 Answers
You are wanting to use the Broadcast feature of your fax machine. According to page 65 of the users manual, you load the documents, press Broadcast, and enter the receiving numbers by using the rapid keys, speed dial keys, group keys, or individual telephone numbers (maximum of 20) pressing Start/Enter between each of the entries (except for the rapid keys and speed dial keys). Set your contrast and resolution (if desired) then press Start/Enter twice to being.
Posted on Feb 01, 2010
How come my shartp fax does not send but can receive
is the line good? tried several different numbers? might have a bad fax board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 20, 2014 | Sharp Office Equipment & Supplies
Broadcast fax
Hello
This broadcast fax service needs to first be set up by your telephone provider. you then give them a list of the numbers, then they give you a central number to send the fax to, which is then relayed to your list!!
I hope this helpsRegardsGrant
Nov 14, 2011 | Brother MFC9460CDN AllInOne Laser Printer
I need to send 1 fax to several recepts
You can send a fax to up to 142 fax numbers, using any combination of dialing methods:
- One-touch Speed Dialing (up to 32 destinations)
Press the desired One-Touch Speed dial button(s)
- Coded Speed Dialing (up to 100 destinations)
Press [Coded Dial] > enter the 2 digit code (00-99) using the numeric buttons and be sure to press [Coded Dial] before each code
- Regular dialing and redialing (10 destinations)
Enter the number using the numeric buttons or [Redial/Pause] and be sure to press [Set] after each entry with the numeric keys
After all the numbers are listed, press [Start]. The machine will scan in the document (memory) and then begin sending it to the destinations in numerical order, starting with One-Touch, then Coded and finally the numbers dials with the numeric keys.
You can also create a group if you frequently send faxes to the same group of people by first saving them as One-Touch and then adding them to a new group.
Apr 13, 2011 | Canon FAXPHONE L170 Plain Paper Laser
I have a 25 page document that must be faxed to several different numbers, on a daily basis. Is there a way I can fax the document to multiple numbers at one time? I am using a Canon Laser Class 2050 P -...
You can't send a fax to more than one number at a time since each fax call needs to be placed separately. But the machine allows you to automate the process by storing the numbers in speed dial as a group, and then sequentially sending the same fax to each of those numbers for you. Full details are in chapter 6 of the manual (available here if you need a copy).
Mar 24, 2011 | Canon Office Equipment & Supplies
How To Enable DTMF Digits on AR_M_280N Fax machine??
have you tried adding * 's they add a pause between numbers. You may have to add several, but that will put a slight delay in the dialing.
Jul 23, 2010 | Sharp AR-M280N Copier
How to send the same fax to several fax numbers?
it's called "broadcasting". open your owners manual, turn to page 7-3, and begin following the directions. quite simple, but too long to explain here.
hth,
razors
Jan 09, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
down on the scanner glass.
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
document.
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
Note
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
Cannot send faxex
Did you try to send a fax to a different number? Also are you sending to a local number? Most send problems are poor phone line conditions. If you have tried to send to several different numbers with no success, then you can assume that the LIU board needs to be replaced. It costs about $40.00 from Brother for the part.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 28, 2007 | Brother IntelliFax-2820 Laser Fax
Sharp FO-4400 Fax Logo
109 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
