Question about Dishwashers
IT RUNS AND YOU HEAR IT BUT DISHES ARE STILL DIRTY AND SOAP STILL ON DOOR.
  • pruittm Feb 02, 2010
    THANK YOU SO MUCH!!! WE'LL SEE WHAT WORKS. I DO RINSE MY DISHES AHEAD OF TIME, IN FACT I AM A LITTLE OCD ABOUT IT (LOL). THANKS
  • 5,081 Answers
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Posted on Feb 01, 2010
  • 1 more comment
  • INDIRA KUMAR
    INDIRA KUMAR Feb 01, 2010
    The detergent cup door opens at a certain spot in the cycle to dump the
    detergent into the dishwasher bottom which would be full of hot water at
    that time. If the door is sticking or the timer is opening the
    detergent cup too late in the wash cycle you will end up with dirty
    dishes and detergent residue left behind. Try dumping some of the
    detergent into the bottom of the machine as well as in the dispenser and
    see what happens.
  • INDIRA KUMAR
    If the spray arm does not spin and spray water when the dishwasher is
    operating during the wash cycle your symptoms fit the problem
  • INDIRA KUMAR
    My last guess is that the impellars which circulate the water aren't
    functioning properly. This might happen if some of the jets are clogged.
    I can't imagine that happening if you rinse your dishes ahead of time
    though, unless your water is very hard and you're getting mineral
    deposits.
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Bottom thing is not turning... suds is running
YOU ARE USING WRONG DETERGENT IF YOU HAVE SUDS TO THAT EXTREME, OR DETERGENT LEFT ON ONE OF THE DISHES. CAN'T SAY THAT I HAVE EVER SEEN ANY SUDS IN A DISHWASHER THAT USED DETERGENT MADE FOR A DISH WASHER. THE SPRAY ARM WILL NOT TURN AS THE IMPELLER CANNOT PUMP AIR (SOAP BUBBLES).
Mar 09, 2010 | GE Dishwashers
Dishes and the dishwasher look dirty after they run, like it redistributed dirty water. The door is very dirty/filmy except right under the soap dispenser, like someone squirted dirty water on it but wiped...
Did you say both of your dishwashers were doing the same thing? Are they the same brand and did you buy them together. It could be a seal in the pumps motor leaking and oil is getting in the water, that is if your pump pumps your water in and pumps it out. Some models the pump pumps the water in and out, other havw a water inlet valve that electrical opens to let water in and the pump just after the cycles pumps the water out.
Dec 30, 2009 | Dishwashers
Water enters dishwasher, soap door opens but soap
That's a normal path for the soap. It sounds like the water just sits in the bottom without being pumped through the spray arms. Does the pump motor run? Pop the door open in the middle of the washing cycle--you should see hot water dripping from everything and the soap picked up and circulated with the water. If this machine has seen a lot of use, the intake screen under the lower spray arm may be plugged and is accessed by removing the spray arm and working your way down to the bottom of the deck. Might be a problem for a service technician to take care of.
Jul 19, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
DIRTY DISHES ,HAZY GLASSES.ALL SOAP NOT GONE
Sounds like the heater is not working, could be bad heating element, bad door switch, or bad heater relay on the main control board. Check for continuity on the heater element to rule out a burned out element. Do the same for the door switch, if all checks out good then replace control board with heater relay.
Feb 23, 2009 | GE Dishwashers
Have the Kenmore Limited Edition dishwasher, model # 665.15892100. When dishwasher is running, you can hear the soap container flip open. However, @ end of washer's completion, and main door is opened, the...
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Feb 02, 2008 | Dishwashers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Owen Barnes
