Question about Kodak Easyshare M341 12.2MP Digital Camera with 3x Optical Zoom and 2.7-inch LCD
The camera turns on and immediately turns off. no warning signs!! just stopped working. is there any way i could format it or send it in somewhere? its practically brand new!!
  • 583 Answers
It sounds like depleted batteries. If you've replaced the batteries, then you may want to pursue warranty replacement. A high Mega-Pixel camera like yours will drain batteries quickly.
Posted on Feb 01, 2010
Where is the oil sending unit on a 1996 mercury cougar xr7 ? Its cause my oil pressure gauge is bouncing up and down...i dont know why...can anybody please help me thank you so much
The low oil pressure warning lamp will illuminate anytime the ignition switch is turned to the ON position without the engine running. When the engine is running, the light also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
If the oil pressure light does not work, perform the following:
  1. Turn the ignition switch to the ON position.
  2. If the lamp does not light, check for a broken or disconnected wire around the engine and oil pressure sending unit switch.
  3. If the wire at the connector checks out OK, pull the connector loose from the switch and, with a jumper wire, ground the connector to the engine.
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp lights, make sure the oil pressure switch is properly grounded in the cylinder block, and if so replace the oil pressure switch. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
To diagnose an oil pressure light that stays on, perform the following:
  1. Check the engine oil level and top off as necessary. If the engine was 2 or more quarts low on oil, test start the engine after topping off the oil level and recheck the oil pressure light operation. If the light stays on, stop the engine immediately and go to the next step.
  2. Disconnect the wire at the sending unit, then turn the ignition switch to theON position. If the light remains on, check the wire from the sending unit to the gauge for being shorted to ground and repair as necessary. If the light goes out, turn the ignition switch OFF and go to the next step.
  3. Replace the oil pressure sending switch with a known good switch.
  4. Start the engine and check the oil pressure light operation. If the light stays on with the engine running, stop the engine immediately to avoid severe engine damage until the cause of the problem can be determined.
WARNING
If the oil pressure light remains on while the engine is started, stop the engine immediately. Do not operate the engine until the cause of the problem can be determined. Operating an engine with low oil pressure will cause severe internal damage.
Possible causes for an oil pressure light to stay on are:
Pinched or grounded sensor wireDefective oil pressure sending unitRestricted or severely leaking oil filterExcessive internal engine bearing clearance.Insufficient or severely contaminated engine oilBlocked oil pump pickup screen or severely worn oil pump
Mar 31, 2016 | Mercury Cars & Trucks
D80 will not turn on...battery fully charged
Do you get any numerals in the TOP LCD? Say a flashing ERR?
Or just no power and nothing works?
Jan 22, 2013 | Nikon D80 Digital Camera
Dell Inspiron 570 loud hard drive hum.....(?)
Any strange noise like excessive clicking, grinding, some weird sounds etc. actually indicate a failing hard drive.
Failing hard drives often show warning signs of their imminent demise. If you're lucky enough to see or hear one of these signs, stop what you're doing and immediately back up your data. They say prevention is better than cure so if your computer's hard disk is making some strange clicking sounds, BACK UP YOUR DATA IMMEDIATELY (As the drive is not operating smooth and may fail anytime).
After making backup of your important data on CD/DVD or External Drive, you may scan the drive for surface errors, format it and see if it works properly or not. It would be better if you seek professional assistance for examination of the disk.
Hard drives are mostly under warranty for at least one year. Claim warranty, if possible.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Nov 23, 2011 | Dell Computers & Internet
My camera dropped down and after checking found working normal. Later it hit somewhere and stopped working. Now its turns while switching on and immediately turns off itself
the circuit in the camera has broken down, it needs to handle technically, it is suggested that you may contact nearest cannon service center.
Nov 23, 2010 | Canon IXUS 960 IS Digital Camera
My freetalk buddy webcam doesn't stream. can't find the software
Open Windows Live Messenger
Click ( > ) Show menu > Tools > Audio and video setup - set mic as default - test > Next - set webcam as default - adjust settings > Finish
Sep 22, 2009 | Microsoft LifeCam VX-3000 Web Camera
Unit comes on then almost immediately getting a warning sign, like perhaps the AC cord is not working. G720 Tom
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work
Sep 14, 2009 | Tomtom GPS
Zen nano plus
Change the battery, or send it to somewhere to get it fixed.
Mar 30, 2008 | Creative Labs Zen Nano Plus MP3 Player
Canon powershot A95 digital camera stopped working
It needs to be repaired.
You may be able to have it repaired for free under the following Service Notice: click me.
" Effective immediately, and regardless of warranty status, Canon will repair, free of charge"
Please rate FixYa! ThankYa!
Dec 06, 2007 | Canon PowerShot A95 Digital Camera
Battery EXTREMELY Exhausted
You MUST use rechargeable batteries , like NiMh , with charger for that kind of battery , and your problem will go ...
May 25, 2007 | Nikon COOLPIX L3 Digital Camera
Kodak Easyshare M341 12.2MP Digital Camera with 3x Optical Zoom and 2.7-inch LCD  Logo
238 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
