Question about Linksys WRT160N Wireless Router
I receive the 322 error when I´m trying to install my new WRT160N v3 Router, by Cisco.
  • ja_heredia Feb 01, 2010
    Well, yes. I´ve been trying to install the router using the CD included in the box, but I'd never thought that the CD would have a problem like that.
    I'm sure my computer is able to go online through the modem only, but I can't finish the router instalation and, if I connect the PC and the modem to the router, I can´t open the IE.
    How can I access to the set up page of the router?
    Excuse me, I´m an average guy on PC problems, not an expert. Thank you.
  • 2,260 Answers
I think you are trying to install the router using the CD. This CD has a bug. Even if your computer is connected to the router , it will say the computer is not connected to the router and it will give you error 322 or 321.
You can install the router without CD also.
Make sure that your computer is able to go online through the modem only.
connect the computer and the modem to the router and open the set up page of the router.
On the set up page you can change the settings of the router according to ISP.
Click Here for step by step instructions
Posted on Feb 01, 2010
Testimonial: "I've got a very useful answer by the experts on this website, and I´m starting to believe that my problem has a solution. :)"
  • Prashant M
    Prashant M Feb 02, 2010
    Try EASY SET UP GUIDE . It is very useful and east to follow.
    Click Here
Cisco WRT160N, all 4 ethernet lights on, so as the internet light ( no blinking ) ... power light and wireless light are totaly off. No connection at all. Tried reset, but nothing changed. The temperature...
Does holding the reset button in do anything? If not, might be that the router is simply fried and time to get a new one. If it does react to resetting try just connecting one device to it to see if you can get to the web interface and configure.
Oct 25, 2013 | Cisco Linksys WRT160N ULTRA RANGEPLUS...
How to fix error 322 on linksys wag120n
getting ip starting 169.x.x.x ... cannot access router config page. Even reset don't work
Dec 03, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Lost my installer cd for wrt160n v3
Many newer routers don't actually require an install CD to work.
Connect the ISP modem to the main network port. Now connect the computer to any other port. That's it. All done
This just refreshes your IP. In PC go to Start > Search (run in XP) and type cmd ENTER. In the command prompt type ipconfig /release ENTER. Then type ipconfig /renew ENTER.
Save this information: Linksys WRT160N Login via web browser at 192.168.1.1 User: (none / blank) Password: admin
Oct 13, 2012 | Cisco Linksys WRT160N ULTRA RANGEPLUS...
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
Jan 08, 2012 | Linksys WRT160N Wireless Router
Solution for error 322
From the computer you are trying to configure the router from. Make sure you have an ethernet cable plugged in from the computer to one of the four numbered ports. You do not want one plugged into the wan/uplink port, this port is to be connected to your cable or dsl modem. Also open a command prompt, press the windows key and type "cmd" <enter> then type "ipconfig" <enter> scroll up and look for an IPv4 address it should start 192.168.x.x. If it starts with 169.x.x.x then your computer did not aquire an IP address via DHCP. If it shows as 169.x.x.x type "ipconfig /renew" <enter>. If it tells you, you don't have permission click windows key > All Programs > Accessories, right click on "Command Prompt" and click "Run as Administrator and repeat the last step.
Comment back if you need more assistance.
Nov 20, 2011 | Cisco Linksys WRT54GS2 Wireless-G...
I have tried connecting Cisco linksys router but it gives ERROR 322 NEW ROUTER OR GATEWAY NOT DETECTED...How can I solve this problem please advice
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
Feb 21, 2011 | Cisco Linksys Wireless N Home Router...
When I run the set up wizard for my Linkksys WRT160N V3 router, I get the message "Cisco Setup Wizard requires that one wired network adapter be enabled. Error 314: Could Not Disable Wireless...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 04, 2010 | Linksys WRT160N Wireless Router
Linksys WRT160N Wireless Router  Logo
1,154 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
