Question about Sony Ericsson W200i Cellular Phone
The screen is blank and dark with slight luminescence and I cannot reboot it, I have taken the battery out multiple times to no avail.
  • 1 more comment
  • heatherander
    heatherander Feb 01, 2010
    The only way to turn off the phone, is to take the battery out. I have done all of that. I took out the SD card again. Re-starting now without the SIM card. I have done everything that I can think of. I get the G1 screen and the "android" screen but then it goes blank when I should get the security pattern screen. I haven't downloaded a new app. for a couple weeks.
  • heatherander
    Issi my phone is the G1
  • heatherander
    We are still working on the problem. This did not help me.
    President:
  • 563 Answers
Try these steps:
1.) Turn off the phone.
2.) Remove the battery cover of the phone.
3.) Now you have to remove the battery.
4.) Clean the battery and the cover with a soft cloth to get rid of the dust.
5.) Wait for a few seconds (10-15 seconds).
6.) After that, re-insert the battery back in the phone.
7.) Put back the battery cover.
8.) Then, turn the phone on.
If this doesn't work, try to switch it on without the memory cared. I also need to know whether you have recently install any programs or applications into your phone.
Posted on Feb 01, 2010
  • Naajiyah Auladin
    Naajiyah Auladin Feb 01, 2010
    Can you plug your phone to the PC via USB cable. Try to scan and check if there is any virus or corrupted files or hidden files. Because a virus can also be the reason why your screen is blank,
    Ok, can you tell me if you can see the light on your keypad (if your keypad's light is on).
  • Naajiyah Auladin
    If nothing works, it's the G1 hardware problem. It could be the LCD or the Power ic.
How do brighten the dial so I can see the time in the dark. The watch was in direct sunlight 3 days & I still cannot see thedial in the dark!
At one time luminescent dials were made with Radium Luminous paint with a half-life of 1600 years so the "glow" didn't go away soon. And getting enough of the material to cause it to glow sufficiently was dangerous to the wearer. Since then Tritium mixed with zinc sulfide was substituted. Please see: http://wornandwound.com/2013/08/23/seeing-in-the-dark-luminescence-in-watches/
Later, non-radioactive materials were used. Unfortunately, all these materials decay and are less efficient. If you have a small flashlight you can hold it to the face of the watch and it will then get brighter...for a while. But, soon it will fade again. Holding the watch under a light for a long time won't help. The reason is that the material can't hold a "charge" and the excited materials have lost much of their ability to luminesce.
Dec 27, 2014 | Citizen Watches Citizen Eco-Drive Black...
Power turns but screen stays black no
Sounds like you need a new LCD Screen(is the screen a little lit up or completely blank) If completely blank than most likely the LCD needs to be replaced if it appears to be slightly lit up than most likely it is a software related issue.
Mar 31, 2014 | HTC Cell Phones
The viewing screen is dark when I go to take a picture. It works when I am reviewing pictures already taken.
You could try and connnect to your camera to a desktop or where ever you save your photos to. A settings reboot may be needed to refresh your cameras software
Aug 06, 2012 | General Electric A1250 Digital Camera
Aspire d150-0Bw dark or blank screen
does the screen has power? even if it has blank/dark screen you can still tell if it has power. if it does try disconnecting and reconnecting its cable but you are going to open the laptop hardware. try cleaning the connector but if it doesnt work i guess you will have to buy a replacement. if it does not have power. you will still do the same thing. the connector could be disconnected.
Aug 22, 2010 | Acer Aspire One PC Notebook
I stop using my TI-86 for a few months and know
I hadn't used mine in years and had the same problem. Essentially you just need to give it a workout to get all the pixels working properly again and then it'll be just fine. I adjusted the contrast between full dark and nothing multiple times and turned the calculator on and off after each cycle and now it works like new.
Jul 06, 2010 | Texas Instruments TI-86 Calculator
Monitor screen ia blank
open it and see if you can find a blow capacitor on the logical lcd board...it´s very common to happen in this kind of model...
Good Luck!
Dec 04, 2008 | Gateway FPD2275W LCD Monitor
Phillips plasma 50pf7320
I have a 50 inch phillips plasma and the pixtals are taking over and color is dark the amblight is very dim,
Jun 25, 2008 | Televison & Video
Dark screen
go to your dispaly setings and check on the contrast and ilumination, if they are low, increase them and the screen will be bright
May 16, 2008 | Nokia 6133 Cellular Phone
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
No picture on lcd screen
I have the same problem but sadly no solution.
As my camera is still under warranty I took it back to Jessops.  The camera is now with Olympus for repair.  The technician in Jessops hazarded a guess that the problem is a broken processor sitting behind the lens and as such the problem is "really bad".
Here's hoping you are still under warranty.
Oct 22, 2007 | Olympus Stylus Verve / ?-mini Digital...
Sony Ericsson W200i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
