Question about Philips Magnavox 51MP392H Rear Projection Television
7P5441 C101 54in color is wrong
7P5441 C101 54in rear projection. Picture is hazy. On screen controls are green on green. Alot of orange and green.
  • Philips Master
  • 3,459 Answers
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
7P5441 C101 54in color is wrong - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 03, 2010
Picture cloudy hazy
based on model number it could be cleaning or another issue--with color turned off what color is the screen? On this set with back removed also clean the 3 large lens as if dusty picture will be dull and somewhat dark.
May 03, 2012 | Philips 60PP9202 60" Rear Projection...
We have a Hitachi LCD rear projection Tv, 42V710,42V715, The picture has alot of green in it, tried ajusting the color, still a hint of green. It was fine until about a month ago. Every thing esle is...
You need to adjust the Green Screen Drive Located on the Focus/Screen Control Block Their will be 3 on Top to adjust Focus to each Tube R/G/B and under it is 3 Controls to adjust Screen Drive to each Tube R/G/B . Cleaning the mirror and Top of Tube Lenses will help improve Picture also if they are Dirty. Control Block is Located behind Front Bottom Panel Pull it off and you should see it.
Oct 05, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Green hazy upside down arch of color across the screen
Your convergence board is in need of reworking on a component level or replacing the board! And you will most undoubtedly need to resolder the vertical IC and all ICs mounted on heatsinks on the power supply board. This TV is showing its age. You may choose to repair and that may last a year more or so! Good Luck and thank you for asking!
Jun 20, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Hazy and messed up color
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 22, 2010 | Hitachi 50UX57B 50" Rear Projection...
The picture looks hazy and anything that is white has a certain glow to it
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 04, 2009 | Philips 51PW9363 51" Rear Projection...
My philips 50" projection tv screen looks green or light blue
the picture tubes are liquid cooled,coolant is contaminated and mist be changed.any questions just give us a call 410-388-9399
Sep 01, 2009 | Philips 60P8341 60" Rear Projection...
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
Philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips Magnavox 51MP392H Rear Projection Television Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
