Question about Samsung 56" Slim-Depth LED DLP HDTV
How to clean 55 inch led tv samsung I noticed a child's handprint on the screen and tried to clean with lysol mutipurpose cleaner on a paper towel then windes glass cleaner on a paper towel trying to touch the screen lightly screen is hazy where i tried to clean it
  • 69 Answers
These tvs have a thin layer of plastic over the outside of the screen. no chemicals are to be used except for the special screen cleaning solution made for lcd tvs. try purchasing one of those screen cleaning kits from your local electronics retail stores and see if the haze can be removed if not the screen is damaged and there is no fix except to replaced the screen.
Posted on Feb 07, 2010
Main Board for a UN55b7000wf samsung LED TV
The BN97-03189B board is formatted for the screen size of your tv. You would be trying to install a board meant for a 46 inch tv into a 55 inch tv. It just wont work.
Aug 19, 2016 | Samsung Televison & Video
How do I clean hanns.g screen?
Do NOT put any sort of cleaner directly on the monitor. If even one drip gets into the seam around the edge of the monitor, it could break and never work again.
The propper way to clean an LCD or LED monitor or TV is to spray a little glass cleaner onto a paper towel, not too much, just a little, (it should feel cool or almost damp to the touch, but not feel wet or saturated) then gently wipe the screen with the paper towel, without applying too much pressure. If it drips, then you've used way too much.
Oct 14, 2013 | Microsoft HannsG HU171D 17" LCD Monitor
Tartan Pattern on screen of 55 inch samsung led tv
Suspect main board that processes all signal in and to the screen.
If not tried do see if same problem when rear inputs for audio/video are used.
May 25, 2012 | Samsung Televison & Video
I have a magnavox 55 inch screen model nu is 6p5440w102. Picture is dark tried to lighten but wont brighten up anymore.
This is an older set------with back off you will see 3 large black cylinders with lens---these are the red, green and blue picture tubes.
Clean the lens with a lens cloth or paper towel with glass cleaner sprayed on the towel.
Annual cleaning of them is suggested as dust or dirty lens will cut down the brightness---this happens gradually over time and will make the picture darker and somewhat dull looking.
I do it with set on but you should UNPLUG SET and just look to see if dust on lens.
Simple and takes only a few minutes.
Let me know what happens.
Steve
Mar 01, 2012 | Philips Televison & Video
How to clean monitor
Windex and a paper towel for the screen, spray it on the towel and not the plastic, to clean the plastic housing, for stains use Lysol wipes, or another multipurpose cleaner.
Nov 25, 2011 | Computers & Internet
I used a soap/water solution to clean my plasma screen but used a regular cloth instead of microfiber and now there are horrible streaks on the tv that won't go away. Help! Is there anything I can do?
You can try to use a harsher cleaner like lysol but sometimes the streaks are permanent. The screen is glass but some tvs have a glare reduction layer that can be destroyed with harsh cleaners (like lysol). Your soap cleaning shouldn't have damaged it.. I would try just water and see if the streaks change. If they keep changing as you clean, its probably some scummy residue, but if they apprear to be permanent, then it could be damage. I always recommend the store bought plasma cleaner with the microfiber cloth, but if you smoke or have a really dirty tv, sometimes you have to cut it with lysol or something. Clean at your own risk, as anything not made to clean the tv can sometimes cause damage. I've seen paper towels scratch the glossy frames sometimes even.. good luck
Jun 11, 2010 | Panasonic Viera TH-50PX80U Plasma TV
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Screen
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Samsung 56" Slim-Depth LED DLP HDTV Logo
3,479 people viewed this question
Henry  Thomas
Henry Thomas
