Question about Microwave Ovens
Saeco Incanto Classic No coffee is coming out with the grinder on, but it is working when I make preground coffee, slowly but still working. I tried with everything what is recommended by the manual but still nothing. The pump does not start after it greed?s the coffee, it seems to be pressure but nothing happens and it stops. I have had the machine for 2 months and it is having the same problem from the start. Hot water and steam is working good.
  • 3,741 Answers
Try cleaning the coffee grinder check out the valve which gets open to let the coffee pass from the nozzle.but if that valve is not functioning properly then it will not get opened and remain closed so coffee will not pass and get blocked or the nozzle is getting blocked by coffee residue. check out.keep updated.thanks.
Posted on Feb 11, 2010
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Sep 06, 2011 | Microwave Ovens
I need a new lid for my Russell Hobbs 9702 Coffee Grinder but the item is no longer available and I can't find spares. The little plastic tab on the lid has broken off, this tab makes the grinder work...
fold a piece of paper or thin card board and put it in the hole the tab went in and you can have your coffee until you can find a replacement on ebay or amazon.
May 20, 2011 | Russell Hobbs Microwave Ovens
I have a cuisinart ccm-16pc coffee grinder. I need a couple of parts, namely the grinding wheel (that's attached to the motor) and the plastic gromet (for lack of a better word) that fits on top of the...
For future reference the Manual for the DBM-8 is here:
http://www.cuisinart.com/share/pdf/manuals/dbm-8.pdf
Available parts:
http://www.cuisinart.com/parts/coffee_bar/dbm-8.html
Here is another site for parts; they do not list what you are looking for but you can make an on-line inquiry for parts.
http://www.abtecparts.com/cuisinart_grinder_DBM8C.htm
Parts Inquiry:
http://www.abtecparts.com/parts_enquiry.htm
Unlike many appliance makers Cuisinart does not have an on-line search function for service centers. If they could not name one you might try contacting some small appliance repair shops; if not able to help they may be able to direct you.
Feb 13, 2011 | Microwave Ovens
Saeco Royal Professional Espresso Machine Problem IT KEEPS GIVING ME ENERGY SAVING. WHAT DOSE THAT MEAN? I HAVE FORGOT T TURNED ON THESE MORNING. THANKS
There is a main switch on the lower left side, as well as a standby switch on the front. Make sure the main switch is on, and the press the power button on the front. It will warm up & be ready to make a cup of coffee (about 30 sec.) when you select one of the coffee (cup) buttons.
Dec 15, 2010 | Microwave Ovens
After grinding coffee,can you submerse in water to clean
No!!! You can clean the cup that the coffee goes into, but do not get the grinder in the water...
heatman101
Nov 25, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
