Question about Kenmore Dryers
Repeat banging noise in dryer
My wife just started our dryer like normal just now and it makes a loud banging noise three or four times in a row then it stops for a few minutes then repeats. Its a Sears Kenmore 600 series dryer. Any thoughts?
Model #110.77632600
MT4907212
Any info is great info. Thank you.
  • 619 Answers
Sounds as if the drum supports are bad. Replace the rollers that the drum glides on and should be good to go.
Posted on Feb 01, 2010
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Electrolux Washer dryer EWW 1273 banging
I think a sensor is being faulty when you load and go to use the unit. Also might want someone to check out the timer on the unit just in case it is going out on you.
Aug 08, 2012 | Washing Machines
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Kenmore 110.86980800 Dryer making loud banging noise but works
Try this link: https://www.searspartsdirect.com/model-number/11086980800/0582/0151200.html?searchType=modelSearch&q=110.86980800&searchTerm=110.86980800. Under Troubleshooting, click on "Making noise or vibrating". Most likely one of the dryer drum support rollers is bad. The parts bag will have two rollers so you can replace both of them while you have your machine apart. You will find the instructions on how to replace a roller by following the link on that page. Not a very difficult job. I didn't even have to pull the dryer out of the utility closet. Most time consuming part was vacuuming and wiping off everything inside. Went thru a lot of paper towels. The triangular retainers where a bit of a challenge to remove. I recommend some small needle nose pliers and don't worry about damaging these retainers since you get four new ones in the parts bag with the two rollers. The retainers go on both sides of the rollers and fit in a groove on the shaft. When putting the new retainers back on I used a 3/8 nut driver to initially push them on. A small regular screwdriver might also come in handy in getting the triangular retainers past the first groove. Only other surprise for me was the roller on the left side required the removal of a bracket held on by a type of washer retainer which worked on the pinching concept to remain in place. I ended up getting behind it with a small regular screwdriver, then moved it a little ways down the shaft. Then I grabbed it with some pliers and pulled it off. Wonder what engineer figured that one out. A new retainer comes in the parts package. Your dryer might vary a little bit (mine is a Kenmore 110.86873100 electric model) so take pics if you want. One other thing. I supported the front of the dryer drum with my dust buster while I took pics of the motor and pulley system before removing the belt from the motor shaft and pulley tensioner. I also used the dust buster as support when reinstalling the dryer drum. Good luck with the heating element. I haven't had to deal with that problem yet.
Mar 31, 2017 | Kenmore Dryers
Maytag dryer making a loud banging sound
are there shoes in the dryer?is the dryer level?
Aug 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer makes noise and vibrates when starting and stopping
Most likely it is the bad blower wheel. The clothes seems hotter than normal oh yeah bad blower wheel.
May 19, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Dryer making loud and louder noise after about 5 minutes of use
my dryer started making a very loud banging noise when I turned it on. It heats up and the drum turns, but I am afraid to use it.
Apr 22, 2008 | Kenmore Dryers
Dryers Logo
252 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
