Question about Maytag Washing Machines
MAF 1260 6kg 1200 front loader model not washing or spinning, makes all the right noises & clothes are wet but no movement
  • flea1 Feb 01, 2010
    thanks heaps for the advice, I couldn't do it myself but it helped with the repairman
  • 3,230 Answers
Well first of all you can check if it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows- If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, if it's frozen then replace it. If the pump belt is broken or looks quite worn, replace it, but be sure to check the pump pulley before you change the belt. then you can check the Agitator- The inside of the agitator--where the transmission shaft attaches can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator or the transmission spline. Please post comments for more help or information.........
Good Luck!!
Thanks
Posted on Feb 01, 2010
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Washing machine shake &makes noise on spin,water doesn't drain completely out.Cothing are still wet
Don't know what type of washing machine you have since you did not provide a model number. But if it is a front loader, and it makes a loud noise when spinning, the problem could be that the support arms have failed. It would cause the machine not to be able to spin properly. To confirm the problem, unload the washer. Spin the wash drum by hand, and notice if the drum sags or wobbles when it spins. If it does not turn smoothly, then chances are the spider arms are broken. It is big job and expensive to fix. Get a few estimates before deciding whether it worth fixing.
Oct 05, 2010 | Maytag Washing Machines
Admiral Washer makes loud steady noise during spin cycle but washes clothes & completes cycle. Possible bearing problem?
If a front loader type, try lifting up on the drum. If it clunks and seems to move somewhat easily, it is probably the front bearing on drum rear support shaft--a major tear-down to replace. If a top loader, try tipping the basket (that spins) in several directions--if it makes clunking sounds, try removing the agitator and check the tub mounting bolts at the bottom center for tightness. If ok, tip the tub again and watch for movement. It may have a bad bearing below the tub at the center area. Remove the tub bolts and pull the tub out revealing the drive hub underneath. Don't know if you would have to drop the transmission to repair what you find. Good luck!
Mar 17, 2010 | Washing Machines
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
May 16, 2009 | Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
We have a front loader Kenmore machine with a spinning problem
i would take the lower panel off and check to see if the shocks are broken
Jan 19, 2009 | Kenmore Washing Machines
No final spin
is there stil standing water in the unit at the end??
Jan 26, 2008 | Frigidaire GLTF530DS Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
