Question about Singer 7442 Mechanical Sewing Machine
Won't stitch a buttonhole
I just bought this machine and getting a hold of support at 1-800-4-singer is a joke. Its always busy. I will load the buttonhole pressure foot and have all the settings correct but when I push the foot pedal it will just beep. Nothing will move. Is there a secret step that is not mentioned in the almost worthless manual?! :) I LOVE the machine so far...
Thanks but I did have this done. I actually (finally) got through the customer service number but they couldn't help as I didn't have the machine in front of me because I have to call from work during their hours. I tried it two times the orginal time and then again today so their only suggestion is to take it to a warranty shop and the closest one is 3 hours away. If I can't get it figured out this week I'm just going to return it and go with a Kenmore that my mom has and has never had a problem with it. Thanks for your help!! I really appreciate it!
Posted on Feb 20, 2008
    New Friend:
  • 185 Answers
Your machine is telling you that you have missed a step.
Probably the buttonhole lever is not all the way down. it is left of the needle at the top of the machine by the lamp and has a picture of a button hole on it.
Hope this helps
Posted on Feb 19, 2008
Do you have the little slide down foot in place? it goes between the two wall like pieces on the left side.
Posted on Feb 05, 2009
  • lktahoe4two Feb 05, 2009
    go through each step again, threading the machine properly. Do you have the button in place at the back of the plastic piece? The little pull down arm in place? Do you have the setting on buttonhole?
    I had the same problem, my husband and I sat there thinking how dumb can we be. then I came to this site and looked for the owners mannual a bang there it was, I forgot to set the setting on buttonhole!! Now I breeze through buttonholes like a pro.
    Don't give up. Go to you book, read each step slowly, you will get it.
Singer 1036 1-step buttonhole foot. It will make 1 perfect buttonhole. When I try to make the next one it makes a short buttonhole, never moving forward enough to hit the lever.
Possibly your machine does not make repeat buttonholes and you need to set every time? Are you stitching all the way around before resetting.
Dec 17, 2016 | Singer Sewing Machines
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
Buttonhole pattern Wheh I select the buttonhole pattern that I would like I get an error. The machine sews on every stitch but the buttonhole pattern.
Are you using the buttonhole foot when you try? It will look like this.
Also, there is a lever you need to pull down to deploy when stitching buttonholes. It triggers the machine to stop stitching out the side of the buttonhole, reverses then does the other side. Its a little lever up in the head near the pressure foot bar and needle bar. It will touch the sticking out finger on the buttonhole foot to trigger the reverse motion in the programm.
Oct 25, 2011 | Singer CE-200 Quantum Futura Computerized...
My singer 7444 makes beeping sounds when operated, the machine fails to start.
Ensure that your stitch width and your spacing are set to a green-light setting. Also, ensure that your stitch wheel will operate(It will lock in the case of a jam.), and check to see that the stitch you have selected is compatible with the kit load you have onboard, i.e. for buttonholing, ensure you have the automatic buttonhole foot attached and the buttonhole lever down. In all other stitches, ensure the buttonhole lever is in the full up position.
The 7444 Precision is a "Smart" machine, and will not allow you to attempt a stitch that simply will not work with the wrong stitch spacing and width settings applied. Move the sliders slowly until each one lights up green, or at least does not light up yellow/orange at all.
Feb 08, 2010 | Singer 7444 Mechanical Sewing Machine
The buttonholer doesn't work right.
Most sewing experts will tell you that the best buttonholes are made with the Singer Buttonhole attachment that has been available since the 1930's. It makes perfect buttonholes every time. Everyone complains about the modern machines not making great buttonholes and not working correctly. Just do a quick search on eBay for one of these vintage attachments and your problem is solved once and for all. Don't waste all the time and money trying to get your machine fixed to only find it does not make good buttonholes...the best solution has always been the buttonhole attachments made by Singer, which the professionals use even with modern machines. They can be found in low or slant shank.
Oct 04, 2008 | Singer 2662
Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual. 1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
Mar 28, 2008 | Singer 7422
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Singer 7442 Mechanical Sewing Machine Logo
137 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
