Question about Husqvarna Viking 1
Husqvarna/Viking SLE 6570 only sews "backward"
I inherited my grandmothers sewing machine. The reverse button feels "loose" (there is no resistance to "push in" to make it reverse) and it will ONLY sew backwards. HELP!
  • Kristine Miller Feb 01, 2010
    I was hoping not to have to take it anywhere. All the parts move -- it's almost like a spring is missing.
    Guess it's a search for a vintage repair person.
  • 2,926 Answers
It should not need a part for this repair. The reverse mechanism inside the machine is stuck from old grease which has hardened. It should be seen by a tech, so the part can be cleaned out. He may also find a broken take up slide or a cracked pattern mechanism.
Get an estimate before you have any work done and ask about a warranty for the work they plan to do.It may be less expensive to buy a newer machine
Posted on Feb 01, 2010
How do you wind a bobbin on a Viking 6570 sewing machine?
Unfortunately, I'm unable to locate a web site or video for this beautiful machine. You can get a user manual from Husqvarna/Viking here:
Husqvarna Viking sewing machine manuals
Service manual here:
Viking Husqvarna Sewing Machine Service Manuals
Not your model, but may be helpful:
Demonstration Video of Vintage Viking 6690 Sewing Machine
viking husqvarna 6440 sewing machine
Aug 03, 2017 | Sewing Machines
I need a VIKING SLE 6570 SEWING MACHINE MANUAL
Please type "Viking SLE 6570" into your search engine of your computer, and you may begin the search for this book.
You will get a bunch of dealers, you can call them and ask how to get the manual.
One should be able to help your.
God bless your efforts.
Nov 11, 2016 | Sewing Machines
Buttonhole
Set the machine to button hole and use the "C" foot. The machine sews backwards first. When it reaches the correct length push the reverse button. Then when it has sewn the left side even with the right side push reverse again.
Dec 23, 2013 | Husqvarna Viking 1
Will only Sew in reverse.
Could be several things -- motor hooked up backwards, reverse is stuck, etc. Is there a Reverse on the machine? If so, what happens when you activate the reverse. If it then sews forward I would say someone hooked the motor backwards. If there is no change, it would be a problem with the feeding motor or the circuit board. Suggest taking to a reputable service center for analysis. Good luck.
Feb 01, 2010 | Husqvarna Viking 1
Machine sewing backwards only
If you machine was recently serviced, the service tech might have reversed the motor connections. If not, it could be the zero feeding mechanism is stuck. Try dropping your feeddogs, i.e. like sewing on a button. Then raise your feeddogs to see if the problem clears. What happens when you sew a buttonhole using the automated buttonhole accessory? If these do not work, it may be your pc board which has a 5 year warranty if you are the original purchaser from an authorized Husqvarna Viking dealer. If resetting feeddogs does not clear the problem, Will probably need service by an authorized Husqvarna Viking dealer. If the service tech cannot repair, they can send to Husqvarna Viking Service Technician for repair. Visit the Husqvarna Viking website for a list of dealers closest to you. http://www.husqvarnaviking.com/us Good luck.
Sep 23, 2009 | Husqvarna Viking 1
OUR Husqvqrna 5310 suddenly started sewing backwards
Problem is probably with the feed stepper motor or the reverse cams are locked. What happens when reverse button is activated. If no change it's probably the feed stepper motor. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Sep 12, 2009 | Husqvarna Daisy 310
Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Jul 14, 2009 | Husqvarna Viking 1
Repair and opertors manuals?
The cheapest manual I have found for the model 6440 is at http://gotoes.org/sales/VikingSewingMachineManuals/ViewInfo.pl?Viking=1&Sewing_Machine_Model=6440
It is a downloadable version also sent by email.
There is a free threading diagram including bobbin info at www.sewusa.com. Repair manuals are available on ebay and run ten dollars or more.
Oct 27, 2008 | Sewing Machines
Sewing Machines Logo
792 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
