Question about Minolta X-700 35mm SLR Camera
Jammed film advance lever
I can't advance the film, and the shutter won't release either. Batteries are fine. The take-up spool and sprocket wheel are turning fine.
I did notice a crack on the plastic top cover, on the side the film advance lever is on, when someone returned it to me.....but I haven't gotten deep enough into the camera to find out if the mechanics of it have been damaged. Is my continued search likely to lead me to a solution?
  • 1 more comment
  • daver473 Feb 19, 2008
    Say...I really appreciate your response. It's getting harder and harder to find help for this school program equipment.
    Answer: Yes, and yes. The led's light up, and go off when I press the shutter release fully down. (And still no actual shutter release....)
    Say...I really appreciate your response. It's getting harder and harder to find help maintaining this school program equipment.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Turn it off, then back on, press the shutter release lightly to activate the LEDs in the viewfinder. Do they light? If so, Do they got out when you press the release fully?
If the lever feels soft then you might haven't moved it till the end so try to push it untill u hear a tick if not then it's the capacitor
Posted on Dec 20, 2009
  • 667 Answers
There is a capacitor that goes bad in the X series. You can find them on eBay. A simple soldering job. It is in the bottom of the camera, accessible by removing the bottom cover. (4 screws)
Posted on Feb 19, 2008
How do I fix the Advance Lever if it is stuck?
Remove bottom cover and check for loose screw jamming the transport/cocking levers. Also check to make sure the advance shaft screw has not come loose.
Feb 13, 2013 | Vivitar V3800N 35mm SLR Camera
I've just loaded the film into my Canon A-1, and I tried to advance it to the first frame, but nothing seems to be catching the film, and the shutter button doesn't seem to be doing anything either. Please...
What has probably happened is that you have not yet engaged the sprockets into the sprocket holes in the film. Open the back and make sure the film is being pulled by the take up spool under the wind on lever until both top and bottom sprockets are engaged. If there are any torn sprocket holes in the film, cut the damaged film off, cut a new lead in section to half film width, and try again. You will lose a few shots, but the rest of the film will be fine. Shutter won't start working until the film is properly advanced. If you need to get damaged film off the take up spool just press the film return button, the one you would press the rewind the film into the can at the end of the film. It is on the bottom under the sprocket shaft.
Jan 03, 2011 | Canon Photography
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film winder jammed halfway throgh a film and i took that film out ( it expired anyway) and i tired to put new one in but i couldnt becuase the film winder wont move do i have to get this repaired?
Check all the batteries. Get fresh ones. If this is a manual, lever-action film advance and you have a camera with a spring-driven shutter you probably have a stripped sprocket and it needs new parts. If you have an electric shutter but there's one spring driven shutter speed as a backup, try that setting. If it is a totally motor driven advance, try checking the drive battery and clean the contacts. If the motor drive is removeable, take it off and try the lever-action advance. Remember, a group of AA cells are only as good as the weakest one. Good luck
Oct 29, 2009 | Photography
My nikon fm10 film advance lever is stuck, i can't do anything with it
You may end up sacrificing the used film or you can rewind it early.
I have had it happen that the film sprocket holes had striped out causing the advance sprocket to get out of sync with the film making it ride up onto the area between sprockets and creating a jam.
If you can, rewind the film onto the feed roll to preserve the exposed portion and then remove it from the camera.
Try the film advance then with an empty camera, releasing the shutter and repeating the cycle to determine if the advance mechanism will now act as it should; if it does, then the film was probably at fault and it may never happen again.
If you cannot respool the film, I would take it to a professional photo lab and have them unload the camera in a dark room if you want to try to save the pictures already on it.
Oct 01, 2009 | Nikon FM10 35mm SLR Camera
Film Advance Lever and Shutter Curtain
If the film advance lever is "flopping" back and forth, the problem is most likely a jammed advance mechanism inside. The shutter is cocked *mechanically* and released the same way--no battery power is needed. One old trick you could try to release things is to push the rewind button on the bottom of the camera.*sometimes* it will free up the mechanism enough to unjam.
Sep 17, 2009 | Vivitar V3800N 35mm SLR Camera
Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Jun 15, 2009 | Minolta X-370S 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Minolta X-700 35mm SLR Camera Logo
1,183 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
