Question about Hitachi 53UWX10B 53" Rear Projection Television
Hitachi 50UX11K color goes in and out and picture is shifted to the right
I powered on my television and left it run for some time. After it was running for a long period of time the picture cleared up, but the image is shifted to the right and the color goes in and out. When the television is first powered on the picture is scrambled as if the vertical hold is off.
  • 54 Answers
Sir kindly adjust the screnn focus of your tv....thanks and hope too help you gud luck sir!!
Posted on Feb 26, 2008
Cannotget the convergenge of colors right with
I have a Samsung Tantus HDTV 55in. I am not getting a full screen. The screen alignment is shifted to the right. I am not getting the full picture quality, just partial. Can you help me?
Oct 24, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 50UX11K wavy pic rolls
Sounds like the vertical controll circuit, it could just be a capicator that is on that circuit. as per the comb filter its very difficult to repair as the capacitors are micro and difficult to solder unless your soldering skills is very good. The is a place that repairs these comb filters www.ptscorp.com i am not sure at what cost though. At any case you can bypass the comb filter by
1.) getting an s-video adapter for your vcr
2.) connect the vcr to the tv using the s-video adapter
3.) change the channels using your vcr.
I'd rcommend you get a professional to have a look at it and repair it as it is much to difficult to repair your self even if you have the service manual
http://www.eserviceinfo.com/index.php?what=search2&searchstring=hitachi+CL2XXX_all+models
I'd
Jan 03, 2008 | Televison & Video
Since the comb filter is discontinued is will be best to bypass it by using the S-video input especially if you are on satellite receiver or use a composite to S-video adapter if you don't have dish. You might get the adapter at Radio Shack or shop online at Circuit City or Best Buy
Jan 01, 2008 | Televison & Video
My Hitachi 52 inch Projection TV video goes one
hitachi 52' tv...the blue color is off...you can put magic focus on and it still want move the blue back where it needs to be
Sep 10, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi 53" rear projection is losing its picture.
If you are not experiencing any shift in colors, it sounds like the power supply is failing since this will affect all three colors.
Feb 28, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Screen is distorted on rear projection hitachi
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 31, 2009 | Hitachi 51SWX20B 51" Rear Projection...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
Hi
The most likely problem is the auto focus module.
A costly repair.
If you are going to fix it ask for a rebuilt one.
Part# CS00022 R
Feb 29, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 50UX11K picture is scrambled
jansen6pack- I am currently repairing the same tv, what I found is that the video pak is going.I have checked pricing and the unit is about 500 bucks,but if you take it to a repair shop they may be able to repair it or send it away for repair. It may be worth the estimate charge. cooltekFeb.18/08
Feb 18, 2008 | Hitachi 46UX50B 46" Rear Projection...
Digital Array?
I have the very same problem. Was there a solution to landfill2004?
Nov 13, 2006 | Hitachi 50GX30B 50". Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
145 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
