Led pins on Tyan Tiger S1834
I cant figure out which pins to hook up the HDD led,power led, or reset switch. I see the schematic on the board for the J10 connectors and the only one that i can get to work is the power sw which of course turns it on. Please help??
    Champion:
  • 253 Answers
Http://www.starlino.com/data/remote_pc_switch/images/front_panel_connector.gif
try here hope this helps...
or download the manual from this site
on the page 15 is the configuration
Posted on Feb 03, 2010
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
Hookup of front panel lights and reset switch
Look on your motherboard. the pins have very small writing so use a strong lite. Your motherboard manufactures web site should have the manual. The manual will give pin locations and how to install.
Jun 08, 2009 | Matsonic MS9337c Motherboard
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
f_Panel
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
In need of a wiring diagram or schematic for this motherboard
Yes! I'm back and the reason why is because I HAVE ALREADY GIVEN YOU THE SOLUTION TO THIS PROBLEM...
It's fairly easy to connect hardware and cables to a motherboard most pins are labeled and most connectors don't fit where they don't belong. I do it all the time at work and home. In the last solution, I gave you a link to Tyan's Web site where you can find a manual that will give you the specs, a guide and much more.
Maybe I should have explained how to use that link in deeper detail...when you click that link it will bring up a page providing you with a color image of the board along with specs. If you want the manual which gives you the CONNECTOR PIN ASSIGNMENTS AS WELL AS DETAILED INSTRUCTIONS ON HOW TO INSTALL THE BOARD, then you MUST click the image at the top of the page that looks like an open book (it will take you to the manuals). There are 2 PAGES OF MANUALS FOR TYAN BOARDS. YOUR BOARD IS LISTED ON PAGE 2.
If you follow this link again, you will see exactly what I'm explaining. http://www.tyan.com/archive/products/html/tiger133.html After you get to the Web page, click the icon that looks like an open book (when you place your pointer over this icon the book goes away and it says MANUALS). Now click it. On the next page, you will see MANUALS/ADDENDA and, just next to this is another one that says page 2, now click it.
On page 2, scroll down the list until you see Tiger 133 [Addendum]. Click the name of your board and the next thing that will come up is the EXACT manual that you're in need of. I promise!
Here is a link to the manual itself...take a look. You can also click the link in the paragraph above to go directly to the installation guide.
ftp://ftp.tyan.com/manuals/m_s1834_120.pdf
Now you should be able to get this bad boy running!!
I know that this will solve your issue as I followed these links both times to make sure the information I provided was accurate. This user guide tells you everything you need to install the board...even gives you explanations of the beep codes (which is very handy to know after installing a new board).
After you click that link and it takes you to what your looking for, can you please be kind enough to rate this solution accordingly.
Thanks!!
Apr 01, 2009 | Tyan Tiger 133 S1834 Motherboard
Need a schematic for this motherboard tyan tiger 133 (1834)
I found the information that you are looking for and you will find it here: http://www.tyan.com/archive/products/html/tiger133.html. This page on Tyan's Web site will provide you with a color image of the mother board (with slots labeled) along with the specs for the board. I hope this is exactly what you need.
Thanks for using Fixya and please rate my solution.
IT_GURL :)
Mar 27, 2009 | Tyan Tiger 133 S1834 Motherboard
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Manual to tyan s239001
Try This link to Tyan Archive Files.
http://www.tyan.com/archive/support/html/manuals.html
I think your board will be here.
Trinity KT Manual under Socket 462/A ( AMD Athlon/MP/Duron )
Mike @ Compurepair.
Mar 12, 2008 | Tyan Thunder n6650W Motherboard
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
