Question about IBM Computers & Internet
Network card not picking though cable is plugged in
  • 29 Answers
Assuming that you see the network card in the Device Manager do this:
Try another network cable,
if that doesnt work then reseat the network card,
if that doestn work then replace the network card.
Posted on Feb 01, 2010
My dell GX620 desktop does not power when ever I plug in the network (RJ 45) cable. Also if the system has boots to desktop, and I plug in the network cable it automatically goes off.
1) Does it have a separate Ethernet Card, or is it integrated?
(Part of the motherboard)
Reasoning?
The Dell Optiplex GX620 comes with Integrated networking.
The chipset is a Broadcom 572.
It's part of the motherboard, and you plug the Ethernet Cable into the back of the computer.
However, you could have a separate Ethernet Card, plugged into the white PCI expansion slot on the motherboard.
http://www.ebay.com/itm/Dell-Optiplex-GX620-SFF-Motherboard-F8101-KH290-PY423-20-Available-/370743464509?pt=Motherboards&hash=item565208523d
A) If you are using a separate Ethernet Card, replace it.
B) If you are using the Intergrated networking of the motherboard, (Plug Ethernet cable into back of computer), use an Ethernet Card instead.
White PCI slot.
You have a short circuit when you plug the Ethernet Cable into the motherboard. Don't use the motherboard networking, use an Ethernet Card.
2) Plugging an Ethernet Cable into a computer that is on, = No.
It is not a Plug N' Play item.
(Not stating this is what you are doing.
Just posting in case you are. Burns out the Ethernet chipset on the motherboard)
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 20, 2013 | Dell OptiPlex GX620 PC Desktop
Ethernet issues.
Can you plug pick up internet with a different laptop in the same place? If another laptop can plug in with the same ethernet cable and get a signal then you know its "your" laptop and not the cable or the connection, If it is your laptop that is the problem, check to see if your network card is working properly by going into device manager. My guess is you need a new network card.
Aug 20, 2012 | Toshiba Satellite L655-S5156 Notebook -...
A network cable is unplugged
This could be caused by a few things. Make sure your cable it plugged into the Router and the Network on your computer. Also make sure there is a green light on the Router and your Network card, if not you might have a bad cable. Swap out your cable first to ensure the simplest fix is tried first. Also try another network plug on the router (If you only have one plug, go to the next step)
If your still having issues, try to replace the network card on your computer, this is probably going to cost around $10 - $15 at most.
If you are still having issues you will want to replace your router.
May 02, 2011 | Computers & Internet
BUILT IN ORINOCO WIRELESS ADAPTER DON'T DISPLAY ANY NETWORKS
Maybe your internal antenna has come unplugged. Try opening the back plate and looking at the wireless card, usaually they have a black cable and white cable pressed onto two studs on the wireless card. carefully try to push the cables down firmly onto the card. NB this may void your waranty make sure battery is taken out before you start and not plugged into mains.
Mar 25, 2010 | MPC Computers TransPort GX3 Notebook
How do i set up 2 IPs on my system so they dont clash??
The best way is to use two different NIC's (network interface cards) in one machine.
After you install the second NIC card plug a cable into it also so you will have two different cable connected to your router. If you are using DHCP it will pick up an available IP so you won't have any conflict with the first NIC card. If you want to set them up with static IP's open the properties of the first one and copy them exactly except for the IP address. Just give the second card the next number.
Example:
1st card: 192.168.1.100
2nd card: 192.168.1.101
Use the same Subnet, Gateway, DNS 1&2 and if your WINS is setup on card one use the same also.
Mar 23, 2010 | Computers & Internet
I am facing network problem since two days back. plz give me advise what should i do manually.
There can only be 3 problems
1. the network card is stuffed, or disabled - to enable, go to your Control panel, select System, select Device manager, Select Network Adapters, Select your Network Card, right click and select enable(if disable is displayed, then your card is fine)
2. the network cable is faulty - try a new or other cable
3. the network plug, where the cable plugs in at the wall is faulty, or not patched in your server room - this must be sorted out by your Network administrator
Dec 30, 2009 | Nokia 1110i Cellular Phone
Bad eathernet card???
try a different ethernet cable first.
May 28, 2009 | Home Security
Internet
First you need an internet connection, wireless or network cable.
For wireless:
You need the XBox 360 wireless adaptor.
Follow instructions to plug it in, then turn on console.
Go to the Dashboard.
Go to Console Settings.
Then Network Settings.
Then Search for a Network.
When you find your network, select it.
If you have a network code, such as WEP, enter it when prompted.
Now, whenever you turn on your XBox and have the wireless adaptor plugged in, it will automatically connect to your network.
For cable:
Plug in the cable to your console at the back.
Then follow above steps if it doesn't automatically connect you.
To play with mates, you need to purchase an XBox Live Gold Membership.
To do this, you must create an account after connecting to the internet.
To create an account:
Dashboard
Create Account
It will ask you to set up XBox Live and to pick a name.
Pick your name and connect it with a Windows Live account such as hotmail.
Follow steps to input information.
Payment can be automatic to a credit card number or, you can purchase XBox Live Membership Cards at most electronic stores, and input the codes.
You get one month free trial just for signing up.
Now to play:
Find out your friends' gamer tags or XBox Live name just as you made yours.
Push the XBox Guide button in the middle of your controller.
Select Friends.
At the top, add friends.
Input their gamer tag.
When they accept your invite/request, you can invite them to chats and games.
Pick your game, follow the instructions to play a multi-player game over XBox Live with your friends.
Have fun.
Dec 28, 2008 | Microsoft Xbox 360 Console
Cant get network to recognize the cable connection
XP doesnt install the right device drivers for the NIC card (LAN card) if you have the origianl Device utilities disk, you can insert it and find those drivers (they will be checked) if no disk, use another pc and go to support.dell.com and enter the tag# locate the networking device drivers and its going to be a Broadcom 47xx driver. if not that try others till it works.
Dec 24, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
160 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
