Question about Baby Gear
1984 Mercedes Benz Ignition wiring
I recently purchased a 1984 Mercedes 500 SEC & the key will not start the car. But I can jump start it from the started connection block located on the right fender below the battery. I was trying to find some sort of schematic to help me solve the problem
  • erictavitian Feb 18, 2008
    This car is challenging and needs some TLC. Any sugestion will be great. Thanks
    Eric
  • 2,039 Answers
That mean the starter good did you try to start the car in neutral if it start the neutral switch is defective let me know
THANKS FOR USING FIXYA
PIERRE
Posted on Feb 18, 2008
I have a 2000 Mercedes SL500. Cluster is flashing 'start error' and I have a P1570 code. Engine cranks but won't start. Starter has an abbreviated spin time too
code p1570 refers to ignition switch control module/ECM-attempted theft/data bus/not compatible ===causes --wiring--connections--trouble codes stored in other system--ignition switch control module---ECM
If this is a recent problem I would suggest that the ignition switch module be checked/replaced.
Nov 03, 2014 | Mercedes-Benz Mercedes Sl 500 Class Sl500...
I have a 87 300e benz. Radio was left on and drained battery overnight. Tried jumping it today but wont start.
charge battery fully do not jump it turn key on for 30 sec than offf ,car should start
Nov 14, 2010 | 1987 Mercedes-Benz 300-Class
Have mercedes E class key fob will not open doors,
If key will not turn
Car battery flat,charge or jump to activate elec ignition
Feb 06, 2010 | 2001 Mercedes-Benz E-Class
I have 1984 Mercedes benz TD .Recently i cann't start the car key doesn't turn in ignition lock houseing
ignition switches are a known issue with this era mercedes. Not too difficult to change the ignition switch. Google is good source for pics, videos and instructions on this. Be aware that the switch is about $400 from the dealer. You could get one without matching key for alot cheaper if you dont care about that. Also, you can get one without the key lock for much cheaper if you are able to remove the key lock from your existing switch.
Sep 15, 2009 | 1984 Mercedes-Benz Mercedes Benz 300 Class
1989 mercedes isnt starting and will not take a jump but battery has power but the car dosnt i checked the fuses and there good what do i do?
Ignition may be bad or stater/solenoid. Try "jumping" the starter with the key in the on position across the poles with a screwdriver if it turns over its most likely the ignition switch. If it just clicks its the starter itself. Or a little of both.
Aug 18, 2009 | 1987 Mercedes-Benz Mercedes Benz 190 Class
1990 MERCEDES BENZ 500 DIES WHILE DRIVING
When were plugs, wires, cap, rotor and coils replaced? fuel filter another culprit. Fuel distributor is another problem as it is mechanical in your year. Fuel injectors also could be an issue but easily rebuildable. More info wold help but fuel delivery and ignition parts need to be checked and replaced for us to help more.
Jul 29, 2009 | 1984 Mercedes-Benz Mercedes Benz 300 Class
Ignition key won't turn lock ssembly
hi,seem your steering lock mechanism is defective,if you to try,remove your under dash,you can your steering lock, loose bolt in clamp,fine a small lock drill out,then you can turn your ignition switch,you can also remove the wiring in the back of steering lock,renew your lock mechanism,ty
Mar 21, 2009 | 1987 Mercedes-Benz Mercedes Benz 500 Class
Wiring diagram Ignition switch
try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 19, 2009 | 1984 Mercedes-Benz Mercedes Benz 300 Class
Baby Gear Logo
63 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
