Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
I have a Frigidaire Horizon 2000 washer. It fills up but does not spin. It makes a sound and then stops.If you move the dial to the end of the rinse cycle it will start to drain and then spin
  • 37 Answers
SOURCE: Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Posted on Jan 17, 2008
drsn
  • 42 Answers
SOURCE: Washer won't spin or drain
whats the make of your washer, if its the older models it might be the lid switch, switch might be defective, but i still need the make/brand of the unit to be more specific.
Posted on Apr 14, 2008
  • 29 Answers
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
My machine will Fill up with water and stop, does not agitate. I will move the dial and it drained water, rinsed, spin with no problem. I think it did this twice then it stopped on the last spin cycle. ...
The fault is poor contact in the main timer controller unit.
Since it is not progressing the program is not outputing, but when you turn the program works. So the mechanism of the timer is faulty or not contacting on the cycle.
Sep 20, 2010 | Frigidaire GLWY1343AS Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Mar 03, 2009 | Kenmore 43142 Front Load Washer
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Dec 03, 2017 | Whirlpool Washing Machines
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
519 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
