Question about Mitsubishi HC1600 Projector
Mitsubishi HC1600 Projector unit powers on and shuts off after a few seconds
  • 148 Answers
It sounds like the unit tries to power on and in the procces hits a bad component, wich in turn shuts the system down for protection. It sounds like all the problemts the new lcd/plasma tv's are having 2 nowadays, bad capacitors are being used by the billions and now there are millions of (top dollar) electronics out there that are breaking down bgecouse of these bad caps. If you feel, open the unit till you can see the print boards. Google for an image of a "popped" capacitor(cap), they supposed to have flat tops on them, but when bad, the tops bulgde up/out and /or leak a tiny amount of fluid. Replace the popped ones (prob just 1) with one from Radioshack orso, they MUST be of SAME or HIGHER voltage then the one removed, also makle sure to install(solder) it with the negative(-) in the corresponding hole. Most the caps will be 105 temperature but Radioshack only has 85, theyve been fine for my monitors and tvs. The actual fix could be just 20 min at a $3 cost, a repair man charges around 200/300 for a new powerboard...Hope this helps some..if you decide to do it yourself, take pictures as to remember how to reassemble it and watch a video or 2 on Youtube on how to replace capacitors..I m pretty sure this is your problem!...Good luck...Ps bad caps(capacitors) can couse many many different symptoms ie; sound, picture. on off problems, only sound, only picture etc...
Posted on Feb 01, 2010
  • roadtrippin Feb 02, 2010
    Hi there again
    I went over some more projector problems and felt like I had to be more clear and precise, so when someone's unit breaks down, they can open it them selfs and have a look before sending out the (hungry) wolfpack of repair-men (joke!)...I wrote all this previously to guide someone in the process of fixing their lcd/plasma tv, but the process is 100 percent the same, just read "monitor/tv" as "projector"..Here goes the detailed instructions;.........................
    The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in...
  • roadtrippin Feb 03, 2010
    Hi there once again lol,, I found a way to finally upload these pictures of broken/popped capacotors. This should help even more in the diagnosis of your projector powerboard, good luck and please rate, thank you!
Does anyone have a motherboard for a hc1600?
I have a HC1500 Mitsubishi projector, I want a mainboard ...
www.fixya.com/support/t25341711-hc1500_mitsubishi_projector_want
Dec 27, 2014 - Can anybody help me to find one. Brought one mainboard on ebay, i got HC1600's motherboard, HC1600 has a different color wheel from ...
Jan 28, 2016 | Mitsubishi HC1600 Projector
I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this. Can anybody help me to find one
Mitsubishi HC1500 DLP Projector Repair Questions ... - Fixya
www.fixya.com > Forum > Multimedia Projectors > Mitsubishi
Recent Mitsubishi HC1500 DLP Projector questions, problems & answers. ... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
I have a mitsubishi hc1500 projector and it made a popping ...
www.fixya.com/.../t5370392-mitsubishi_hc1500_projector_made_poppi...
I have a mitsubishi hc1500 projector, when i went to turn it off it made a loud ..... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
MITSUBISHI HC1500 DLP 720p Home Theater Projector ...
www.newegg.com/Product/Product.aspx?Item...
Newegg
Rating: 5 - ‎22 reviews - ‎$949.99 - ‎Out of stock
MITSUBISHI HC1500 1280 x 720 DLP 720p Home Theater Projector 1600 ANSI Lumens 2500:1. ... If you are a high-definition video enthusiast who's looking for a more affordable way to bring a front-screen projection to your home theater or family room, the Mitsubishi HC1500 projector is
Dec 27, 2014 | Mitsubishi HC1500 DLP Projector
Recently, out of the blue, my HC1600 projector has been failing to project any image. It makes a clicking noise...then stops...makes another clicking noise and proceeds to flash a green and (stationary)...
Probably a power supply problem. Most likely, there is a power transistor or relay that is not properly powering the light or other equipment. Check the warranty on the device, get a new one if you can. It won't be easy to fix.
May 03, 2011 | Mitsubishi HC1600 Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
What does the status light mean on my hc1600? won't power up
This could be due to a blown lamp in the unit or a temp control unit such as a bad fan or what not. You may want to take it in and have this looked at if I where you. This light is telling us its ether the lamp or the temp controll unit such as fans that has given out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 12, 2009 | Mitsubishi HC1600 Projector
How do I mount the HC1600 projector
there are three screw holes on the bottom of the projector, 2 in the back by the feet and one in the front. they take a standard size, I think it is a 6x4....
I had a infocus projector mounted to the ceiling and took it down this weekend and put the hc1600 in using the same screw and same adjustable ceiling mount.
Dec 24, 2008 | Mitsubishi HC1600 Projector
Mitsubishi HC1600 Projector Logo
595 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
