Question about Lexmark X1150 All-In-One InkJet Printer
Ink cartridges I had my stuff in storage for 2 years, I'm sure the ink for my computer dried. Can I send it back and get some kind of credit for new ink cartridges
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Good luck and let us know if they respond to you.
Posted on Feb 18, 2008
Printer was inactive now won't print
The ink might be dryed up in the cartridge, might need a new one.
Dec 29, 2012 | HP PhotoSmart C4480 All-in-One Printer ...
I have put a new black cartridge in printer but nothing is printing out- when I run a test the color cartirdge are working but not black
Hmmm, make sure it is properly fitting in there.... Take it out and put it back in.... Usually the printer performs some kind of "preparing the ink" operation... SO allow it to does this...... Make sure you are using genuine ink, sometimes printers won't accept non-genuine inks.... Hope this helps :)
Jan 08, 2011 | Brother MFC 490cw Color Inkjet...
My lexmark 3550 printer wont print
Hi
If you have storage your printer for nearly a year then myself I think the heads have gone dry and blacked you will need to clean the heads, if the heads are on the inks then no problem just get new ink but if it been standing that long and the heads are on the printer itself and not on the ink cartridge then you will have to find the heads some will clip out but some will have to be screwed out and then you can clean them by dabbing a little worm water on a cloth on the heads to try get them clean.
It not good to leave them standing, if you go to store them for a long time then you go to take out the inks and clean the heads before storage.
All The Best: Pineworks
Jan 31, 2010 | Lexmark X3550 All-In-One Printer
CX5400 Replaced all ink after months in storage
uninstall the printer then reinstall it according to the setup manual.Make sure you are installing the cartridges correctly.Then print a test page form the properties menu
Oct 07, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Having problems printing after changing ink cartridges.......scanner and copier work fine.....when send the command to print from the computer...it pulls the paper and sounds like it's printing but just...
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 06, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
Printer problem
Take the ink out and try dabbing some alcohol or some kind of mineral spirits sort of stuff on the place where the ink comes out. This will help if the ink has dried onto it. Then make sure you run a few cleaning cycles to clean the stuff out that you used.
This usually works unless you have a bad print head or bad ink.
If this helps, be sure to rate this as a fixya. If this does not help, I will keep trying to figure out what could be wrong.
Jun 10, 2008 | Dell 922 All-In-One InkJet Printer
HP Business Inkjet 1000 error detecting new cartridge
Disconnect the communication cable (USB?).
Turn off the printer, wait one minute then turn it back on,
Then press the left button on the panel, the transparent one to the left of power button. It will print a status page. Check the dates and information under each color that is failing.
The ink cartridges MAY be outdated. Printing the test and information page without the computer connected fools the machine since it can't get your computer date.
If the cartridges are outdated, then change your computer year back to 2005 or so, reconnect the printer cable and send something to print, once the printer prints it out, reset your computer to today's year.
You will need to do this procedure whenever you turns off the printer. (Disconnect cable, change computer year, print, reset computer date).
Hope this works.
Wagner
Feb 20, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma MP830
pleaz alihn the new cartridde by programing or change the ink ,it may be dry
Sep 14, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
