2002 Dodge Grand Caravan Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transmission fluid all leaked out of 2002 dodge grand caravan, are they easy to replace?
Anonymous
Level 3:
  • Master 350 Answers
  • Posted on Feb 01, 2010
Anonymous
Master
Level 3:
Answers
350
Questions
0
Helped
137501
Points
1214
Kelli,
replacing the transmission fluid is easy, but you really need to find out why and from where the old fluid leaked. Under the hood in the engine compartment you will find a dipstick (gauge to check the fluid level) which is essentially the same as the oil dipstick in its performance, but different in location. It should be clearly marked as such.
Pull dipstick out and insert funnel into the opening (filler tube) and add 4 quarts of ATF Plus 3 Type 7176. Start the engine and allow it to idle for approx. 2 minutes
Apply the parking brake and push down on the brake pedal while idling and run the gear selector through the gears, stopping at Park.
Check the dipstick and add fluid so that the level is 1/8 inch below the "ADD" indication on the dipstick if necessary. Allow the van to run for around another 10-15 minutes to achieve normal operating temperatures.
Check the fluid level again to make sure it reached the "Hot" indicator level on the dipstick, and add more fluid if needed and then replace the dipstick in the filler tube.
I would definitely find out why you have leaked all of your transmission fluid before refilling it.
I hope this helps and good luck!transmission fluid all leaked out of 2002 dodge - b989e6d.png
2002 Dodge Grand Caravan leaking fluid
Since the Caravan is front wheel drive, there would be no transmission lines running to the rear of the vehicle. This reduces the possibilities to either a fuel leak, or a brake line. If you smell the fluid you should be able to tell immediately if it were gasoline. This would be a dangerous thing. Fuel leaks must be isolated and repaired quickly to avoid risk of fire. If it were brake fluid, and the leak were stead, you should, if you inspect the brake master cylinder reservoir, a lower level of fluid than normal, possibly even a total loss of fluid in the rear chamber. If so, then the brake line to the rear has probably ruptured from age/corrosion. It must be repaired or replaced.
1helpful
1996 DODGE GRAND CARAVAN LEAKING TRANSMISSION FLUID
IF TRANSMISSION LEAKING WHILE RUNNING LEAKING AT TORQUE CONVERTER SHAFT SEAL OR TRANSMISSION COOLER LINES GOING INTO RADIATOR LEAKING.YOU WILL LOSE MORE FLUID AT COOLER LINE BECAUSE TRANSMISSION UNDER PRESSURE THE OIL PUMP PUMPING IT THROUGH THE RADIATOR YOU WILL LOSE ALL YOUR FLUID QUICKLY IF LEAK COMING FROM COOLER LINES GOING INTO RADIATOR.DONT DRIVE VAN UNTIL FIX BECAUSE FLUID LOST WILL BE TRANSMISSION LOST.
99 dodge caravan 3.3lt leaking transmission fluid out of a rusty side pan. How difficult to replace/fix
even if you bought a new trans pan gasket it will still leak this is a easy repair get a new gasket and silicone (gasket making silicone) use bothe gasket and silicone that the only way you will stop a leaking pan gasket and yes its simple
1helpful
2answers
Will valvoline dex/merc transmission fluid work for my dodge grand caravan? Does the caravan require dextron III/ mercon
Probably isn't a good idea to run regular ATF. Most chrysler products including your Caravan require ATF +4 or equiv. Typically it is more expensive than regular Atf. Most auto parts stores will stock this.
1996 grand caravan leaking transmission fluid. Used lucas stop leak, still leak use 1 liter per 1000 Km otherwise works fine
so i just changed the seal at the front pump and torque converter because trans fluid was leaking from the bell housing took her for a test drive and still leaking help anyoine it is a 1996 grand caravan 3.8
Dark fluid dripping on passenger side inside. 2002 dodge caravan. what would it be? seems to drip only when vehicle running
Could be power steering fluid, or transmission fluid
If its a dirty red color, than thats what it is.
If its black or brown than it's oil,
don't ignore
I have a leak on the right side of the engine,its from a metal pipe connected to a hose that connects to the radiator,what is those parts called? is this an easy fix?
sound like a transmission cooler line/hose. is the fluid red or brown?
if it is then you can just get a transmission hose and replace it.
3helpful
2answers
2002 dodge caravan - transmission slips out of gear, then back in, scan code P0884
trans control module signal intermittent loose connection or frayed wire
4helpful
3answers
Transmission Not Going into Overdrive
First check and make sure the fluid is full. The most likely cause is a failed solenoid pack. Circuit codes normally mean something electrical not mechanical has failed. The solenoid pack is on the outside of trans pretty easy to replace.
2004 Dodge Grand Caravan Water pump
If it's red, it's transmission fluid. Coolant would be green. Check the fluid level, don't let it get low, Chrysler minivans are prone to transmission troubles, and low fluid levels over time will ruin a a transmission. And be sure not to overfill, it's just as bad for the trans. Have the leak checked out and repaired, good luck
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
