Question about Minn Kota 55 AutoPilot Universal Sonar Combo GPS Receiver
I have a 24v pd2 70ib thrust trolling motor. What size batteries do I need
  • 3,051 Answers
Hello there:
the 24v tells you that you need 24 volts ok so what you will need to do is to get 2 12 volt batteries and put them in series than run this to the motor this is usually done with a disconnect switch in the line with your start switch ok? you can also contact the manufacture of the motor for further details
Hope this is very helpful
Best regards Michael
Posted on Feb 01, 2010
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota 65lb thrust 24v
Hello!
Your unit was desined to run on 24 Volts.
The control unit (electronics) will not run below 19 Volts (19 or 20, I can't remember) and the armature windings and magnets are designed for 24V as well. So, an easy answer is no your unit will not operate in 12volts.
Hope this helps out!
Mike
Sep 26, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Install
Click the link below, You do need to know your serial number thrust of motor and length of shaft as well how far away from trolling motor you will install your battery. This link is on Minn Kota Motors website under FAQ you can discuss with a service rep at Minn Kota please call 800-227-6433, but you will still need the information I asked earlier to come up with the answer.
http://www.minnkotamotors.com/_ui/sramk08/tpl/sramk_nohero_banner_faq-item.aspx?id=145&__taxonomyid=977
Apr 13, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
GPS Logo
177 people viewed this question
Top Minn Kota GPS Experts
Will Halftowaite
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
