Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My mitsubushi wd 52525 we replaced bulb but can't turn timer light keeps flashing what do i do
  • 135 Answers
This is due to failing capacitors in the power supply. Many people have fixed them self repair but it takes some skill. If you cannot do this yourself, contact Mitsubishi. They will help with the repair under an extended warranty. You will have to pay labor.
Posted on Feb 01, 2010
I had same problem and I replaced 4 capacitors, and now its on.
Posted on Feb 09, 2010
Hi i have a mitsubishi WD-52525 and the timer light just keeps flashing and the tv wont power on....whats wrong with it?
Check for bad cap on DM & FMT modules 1000uf at 25volts caps to E2P module.
Credit: http://www.repairworld.com
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinking on my WD 52525 tv will not turn on
main board or bulb went out it is a diagnostic indicator used on the timer display to let you know its not working.
Mar 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Flashing timer
Replace the DM capacitors. The V26 DM repair kit from www.tvrepairworld.com should fix that issue. The kit also contains the CD with instructions.
Jan 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The bulbs were just replaced but when I plug the tv in i don't get a picture. Timer light flashes.
The V26 Chassis DM repair kit from www.tvrepairworld.com should repair that issue. The kit contains detailed instructions along with the replacement capacitors.
Nov 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The timer light on my tv keeps flashing and we are unable to turn tv on...help!
The V26 Chassis DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacment capacitors and the CD with detailed repair instructions
Nov 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi tv model wd-52525 and the green timer light is flashing and it will not turn on. Just bought expensive bulb and replaced it and still blinking
Probley should check the DM board for bad capastors. DM board is inside of a metal case should be on left side of tv when looking from rear capastors should be marked 16v 1000 uF on them should be 4 of them about 1 inch tall green or black or blue or brown maybe even yellow in color if bulage on top then then thay are bad if not still could be bad common problem need to check may or may not be your problem does couse the power light to blink non stop.
Oct 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced bulb in Mitsubishi WD-52525 and it still does not work
What does not work? Does the green light flash or light at all? Can you "manually" turn on the tv? If the light is RED...the replacement was either installed incorrectly (or is not plugged in correctly to the contacts at the rear) or is the wrong bulb. Be sure the door to the front of the bulb in on as there is a micro-switch at the lower right that MUST be engaged.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubushi wd 52525 No picture, no sound. Self Dia shows 1.2
No trouble code is 12, is that what your getting? Is red light on all the time or blinking?
Jan 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525
This chassis has bad capacitors on the PWB,FMt, DM and the other boards that need to be replaced. They are all jamicon capacitors 1000uf and larger there are roughly 10 in the set that need to be replaced. Let me know if you need further instructions on this model.
Apr 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
280 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
