Question about Maytag MDB7100AWB Dishwasher
Fills with water, sounds like it starts to pump water then stops, then start again. It attempts to start pumping water 3 or 4 times them turns off leaving the water in the tub. I have read about the water needing to heat up for the cycle to advance. When I check the water that is left in the tub it is warm but not hot. The heating element is not hot either. I did a continuity test on the heating element and it seems to check out ok. I also did a continuity test on the red wire from the heating element to the circuit board (ok). Also check the white wire to the circuit board (ok). The thermostat tested positive on the continuity test. The circuit board does not have any visible  flaws or  soder  breaks. I'm wondering if there is a water flow issue. The pumps seems to start pumping but quickly (2 seconds or so) stops then start again. Is there a way to test is this is an issue? Would a water flow issues cause these symptoms? Is there a diagnostic test for the heating element? I already tried the continuity test with a meter? Thanks, Darin Dishwasher fills then I hear a humming and it doesnt wash, Clicks off then hums some more and clicks off. It does drain and fill.
  • 1 more comment
  • Anonymous Mar 15, 2014
    My dishlex 302wj fills with water then nothing happens the cycle continues to count down but no washing happens. i have tested the pump and it works with power applied to it.
  • Anonymous Mar 29, 2014
    water not heating checked element all good circuit board looks ok does it have a heat sensor and were is it
    water not hot but heating element tested ok
  • 49 Answers
You have a wash pump problem. can be 1 of 3 things. most likely something is caught in the pump impelor if not the wash pump motor may be faulty or ceized or it could be the capacitor for the wash pump motor is faulty. you can try removing the wash pump yourself and check the impelor if it spins freely then you will have a motor problem.
hope this helped
Posted on Feb 19, 2008
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 | Dishwashers
Fisher paykel excellence 6.5
take out plastic pump something may be caught in impeller water level sensors control power supply to pump
May 22, 2014 | Washing Machines
Mod: kuds30ixss6 - Making a loud noise
You are going to have to remove the spray bars and the filter at the top of the pump housing to see if something is stuck in the pump
Jan 06, 2014 | KitchenAid Dishwashers
Toyota repair
check for a loose electrical connection or a faulty stop solenoid on the pump or injector controls if common rail . It sound that the stop control has an intermittent continuity problem ( broken wire-dirty connection---bad earth site etc)
Dec 21, 2013 | Cars & Trucks
I have a haier hdc1804tw it starts,pumps out old water, fills new water, than stops. It wont activate. Any advice?
Have you had any luck with this? Ours just started doing this tonight after no problems (had it for 3 years, light use). "Feels like" a pump isn't kicking in to pump the water to the arm.
Sep 14, 2013 | Haier HDC1804TW Dishwasher
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
Sep 14, 2008 | Hotpoint WMA64 Front Load Washer
Maytag MDB7100AWB Dishwasher Logo
527 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
