Question about GE Washing Machines
I have a g.e wsxh206v1ww front load washer that will not spin while draining after the water is drained it trys to spin but acts like it is trying to balance the load three times and the stops
  • theeborg Feb 03, 2010
    do you have a picture of the speed control
    President:
  • 1,891 Answers
You may have a broken shock / this willl cause the machine to try to spin but cannot . after it try's several times the prosser will shut it down. sometimes the shock just has come loose it may not be broken .. hope this helps **** ..
Posted on Feb 03, 2010
  • 291 Answers
Probably a motor speed controller, this is pretty involved to test. Inside your washer is a wiring schematic-tech sheet. This is usually in a plastic bag on the side of one of the walls. Remove the front lower access panel, and see if you can find it. If it is not on the walls, remove the top cover and check from above. Read the steps to test the motor and speed control. You will need an electical tester and will need to know how to use it. If you able to use the tech sheet to find the problem, then follow the steps carefully. Call an appliance technician if this is more than you want to attempt. Good Luck, Appliance Specialists
Posted on Feb 01, 2010
  • Norm Dickerson Feb 03, 2010
    Here is a link to the part at repair clinic. Double check with them to make sure this is the right part number. http://www.repairclinic.com/SSPartDetail... As you can see the part is very expensive, so again make sure this is the problem before your replace the part. When you are done replacing the part or replacing the washer I would recommend that you install a wall mounted 2000 joule or higher surge protecter for you washer. You can buy these at Lowes for about 19.00. If you decide to replace the washer, my strongest recommendation is for the Whirlpool Super capacity front load washer and dryer. Not the sport model. Good Luck, Appliance Specialists
My front load washer do not spin
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out. If helped, pl say so.
Apr 01, 2013 | Frigidaire FAFW3801LW Front Load Washer...
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
When we turn on our front load washing machine it trys to drain. it does not start filling with water it acts like it might be stuck on the drain cycle
Seems it detects water from previous run. Is common phenomenon on bad drain hookups or faulty vacuumswitch. Rarely, the timer is damaged.
Apr 09, 2009 | Maytag EPIC MFW9700S Front Load Washer
Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer Impelling into Hot Water Line
this sounds impossible,hold old is the washer? how long are the hoses to the washer?is it the temp pressure valve on the heater that bursts? can you hear the water draining out the drain pipe, this machine don't go into spin till the water has been drained.
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Jul 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Water drains, but washer does not spin
try opening the filter which located mostly in the lower area of the front side. An acumilation of dirt and calc will inhibit the complete drain of water. After opening and cleaning the filter, put it back in. Once it will drain completly, it will start spinning. Hope I assist you with the problem.
Nov 18, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
27 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
