Question about Cell Phones
The rollerball on my Blackberry Curve wont scroll down
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 153 Answers
You have two options to repair your trackball. 1) you can send it to a repair facility or 2) You can repair it yourself.
To repair it yourself, you will need to gain access the trackball (rollerball) and its sensor and clean them.
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! Like you should be during the whole process as all parts have very small plastic nipple which can break very easy. When the silver plastic ring is removed you will see the inner trackball component which can be removed completely.
Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position. The trackball component itself can also be carved. For every direction the ball can roll towards- you’ll find a sensor wheel. Those wheels are mostly carrying or covered with some gunk you should clean them from.
Once this is done put everything back together to the place the pieces came from and secure the trackball with the silver plastic ring you removed in the first step. Your BlackBerry’s trackball should be back working now.
Please be kind enough to rate my answer
Posted on Feb 01, 2010
2 Suggested Answers
erone47
  • 458 Answers
SOURCE: blackberry curve rollerball won
You probably have dust in it. You need to clean it.
Take it to a service center and they will have it cleaned.
Posted on Dec 30, 2009
Roller ball won't scroll down anymore what can i do?
take a q-tip with a little amount of alcohol and make sure that the phone is off clean the rollerball. it should work fine. try to clean the ball twice a month.
Nov 09, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve rollerball won"t scroll down
Dec 30, 2009 | Cell Phones
I can't scroll down with the rollerball
The balls on the blackberry's get clogged up with finger oil, skin, and all sorts of grime I think. But I fixed mine by shutting the phone down and then rubbing hard against the roll ball in each direction and pushing each time until the clicker under the roll ball clicked. You could also try alcohol.
Oct 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
My Rollerball won't scroll down - tried everything.
Cause: The sensitivity of the trackball/trackwheel might be less Faulty Hardware Resolution: Increase the sensitivity by following procedure Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100 If not working check with the service center
Aug 11, 2009 | RIM BlackBerry Pearl 8100
Blackberry Curve rollerball scrolls but will not select when push
Try removing the silver cover around the scroll ball, and remove the ball. There should be a little white square underneath it. If there is no white square, but a red square, then it could be water damage. I had the same issue with mine.
Dec 15, 2008 | RIM BlackBerry Pearl 8100
BLUETOOTH 8310 blackberry
depends what you are recieving...if its a photo you want to recieve,go to photo album..press left key next to rollerball and menu will come up...scroll down to..allow connection...then press on it.will connectthen get them to send a photo.hoope this helps
Sep 25, 2008 | RIM BlackBerry Curve 8310 Smartphone
Blackberry rollerball
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
HELP!!!!HELP!!!
Try blackberry.com, they will have links to buy parts, also crackberry.com is great too.
May 05, 2008 | RIM BlackBerry Curve 8310 Smartphone
Cell Phones Logo
711 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
