Question about Akai LCT3215/26 32 in. LCD Television
I have only one TV since my last one went out and now it will not turn on. When my fiance tried to use it two days ago it would turn on then when the blue AKAI screen appeared it would turn back off. The next day it wouldn't turn on at all. So I unplugged it and unhooked all the appliances from it and then plugged it back in and it turned on. Today it will not turn on at all it is just making this high frequency humming noise and it only clicks when I hit the power button. The light is red and it will not turn green. What is going on and how do I fix it? I have the back off and all dust has been cleaned off and there is a little black box that clicks when I hit the power button but I don't know if that is the problem. I really need this TV to work and any help would be greatly appreciated. Thank You!!!
  • Akai Master
  • 1,527 Answers
Hi the black box is the relay, look for swollen tops on the capacitors thanks
shaun
Posted on Mar 17, 2017
  • 4 Answers
SOURCE: power light blinks red - tv will not come on
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Posted on Jul 24, 2008
  • 8 Answers
SOURCE: AKAI LCT3285TA seems to be stuck in "Standby"
Greetings,
We own a small TV repair shop in Ohio and have ran into similar problems with this TV.
To fix this problem we replaced 3 caps near and in the powersuppy of the TV.
This TV is very sensitive to electrical problems ( more then most if that's possible) so check the caps near the PSU.
Over all this TV is a fairly decent product.
Posted on Oct 31, 2008
  • 2336 Answers
SOURCE: AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
  • 2336 Answers
SOURCE: I have a 32 Akai HD TV I found the following
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV. I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Jun 15, 2009
  • 157 Answers
SOURCE: Akai LCT3285TA Television won't turn on
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
Posted on Sep 24, 2009
Testimonial: "Dale Hunter's response was completely accurate. I replaced the three capacitors that he identified. And it has been working fine since 2009. Now I have the black screen problem. Help me Dale."
No picture still have sound HELP
If you have not tried it: unplug the set and if using a cable or sat box unplug that as well---wait for a while and plug both back to see if a reboot of either cures the problem or not.
May 25, 2012 | Samsung 50 in. Plasma TV
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Sep 15, 2010 | Philips 55PW9363 55" Rear Projection...
I have a GE TV model: 27GT271 and no sound
Possible cause of the problrm is bad/poor solder on the grounds for the tuner circuit shield an the bottom (solder side) of the circuit board. Grounds need a wire jumper from point to point. This was a common problem for those sets and ocassionally it would take out the eeprom chip with it. (Various other problems were shrinking picture/fuzzy picture and intermitt. power)
May 14, 2009 | GE 27GT271 TV
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Tv not turning on
This is going to sound pretty elementary, but my guess is that the power cord is defective. That TV model is relatively new (I have a similar one, bought about 8 months ago) and presumably is still under warranty. I would have the power cord replaced by a repair shop.
May 30, 2007 | Hyundai ImageQuest HQL320WR 32 in....
Flat screen tv is not turning on
not a lot you can do.if you have tried the lead etc then it is a job for a qualified technician
May 15, 2007 | Hyundai ImageQuest HQL320WR 32 in....
Televison & Video Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
