Canon PIXMA  iP1800 Printer Logo
Posted on Feb 01, 2010
Ip 1880. green and orange light blink alternately but green stays longer at the third blink.cartridge also not moving. please help me.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 10, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1240
Points
Try to reset ur printer. first off ur printer and take off the jack,just hold the grin light then plug the jack,and also hold the red light den move your fingers in the grin and red light
3answers
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Canon pixma ip 1880 stop print
If there is no bad sound in your printer, you may need to replace your ink cartridge of reset your printer.
Thank you
9helpful
2answers
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
7helpful
3answers
My printer is canon pixma ip 1980, its orange light is blinking 7 times, it says the cartridge is not installed properly (but i did not even touch the cartridge), how can fix the problem? pls help, i need...
Remove the cartridges, clean the contact points and heads using a soft brush (you can clean them using the brush dipped in alcohol or acetone or spirit). Reinstall them and switch on the printer. If the problem persists, try with another cartridge/s, it's also possible that one of the cartridge/s is/are bad and no longer usable. In that case, you'll need to replace it/them.
Good luck.
Thanks for using FixYa.
1helpful
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
1helpful
Error 6A00
6A00 is AP position error. Check sheet feed unit.In worst case the logic board assembly is defective.
Pixma 1880, 4 orange bliks and 1 green
When it blinks 4 times orange it means that your ink has run out. You should replace the ink cartridge.
On/off button & restore button blink green & orange; printer doesn't work
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
20helpful
7answers
CANON IP 1880
i need install canon ip1880.. how?
48helpful
9answers
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
old marine
old marine
ZJ Limited
ZJ Limited
