Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
How do you access the bulb so it can be changed ? Replace lamp blinks on screen when set is first turned on.
  • 50 Answers
The lamp module is behind the front panel below the screen.
Just pull the panel off. The second cover from the left is for the lamp.
Posted on Feb 17, 2010
2 Suggested Answers
  • 68 Answers
SOURCE: sony kds-60a2020 lamp problem
I would change the whole LAMP ASSEMBLY because if you touch the lamp while changing it out of the housing the oils on your hands will cause premature failure.Most of the time the lamp assembly's come with replacement instructions but yours is not too bad it is located on the left hand side if looking from behind set.
Posted on Sep 10, 2009
Resetting lamp life
was the button sequence given (set off) display,5, volume up, then power?
Mar 21, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Please tell me how to replace a burned out head light, high beam.
To replace the headlamp, turn signal, or parking lamp bulb:This information should be in your owner's manual.
Turn the wheel to access the wheel well.
  1. Remove the fasteners located on the wheel liner. To access the headlamp and the turn signal/parking lamp bulbs.
  2. Reach in behind the wheel well liner and locate the bulb to be changed.
  3. Turn the bulb socket counterclockwise and pull it straight out of the lamp assembly.
  4. Pull the old bulb straight out of the bulb socket.
  5. Push the new bulb straight into the bulb socket until it clicks.
  6. Push the bulb socket straight into the lamp assembly and turn it clockwise to lock it into place.
  7. Reinstall the wheel well liner using fasteners.
Nov 11, 2009 | 2006 Chevrolet HHR
Lamp Out
There is typically an access door on the back of the TV which is used to replace the lamp. Consult your user manual for more details.
Once the set detects that the bulb has been replaced (you may have to tell it via a menu option, but that is a bit rare), it will then take over for calibration and such (if it has that ability).
Be darn careful that you do not handle the bulb with your bare hands. Would be fantastic idea if you were to handle the bulb with linen gloves. It probably is not halogen, but you also don't want to be leaving a print on the mirror or similar.
Sep 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sony kds-60a2020 lamp problem
Sep 10, 2009 | Sony KDS-60A2020 60" HDTV
Sony KDF55WF655 TV ready green light blinks 30 times
Could be a bad lamp again. If this TV uses the XL2200 lamp, they are known for this intermittent behavior. If its not the lamp, a tech can access the self-diagnosis screen to see what's causing this failure.
michtech
Feb 18, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
How do I know it is the lamp, when the TV wont turn on??
If the set is still under warranty Samsung will send you the lamp,
look their number up in your owners manual which will also tell you where the access panel is for the lamp, each model is a little different but the owners manual will explain how to change it, not hard to do once you know where the access is, good luck
Nov 29, 2007 | Samsung HCM422W 42" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
