Question about Technics SL-1210 Turntable
Using Technics SL-B2
I've just been given a second hand Technics SL-B2 turntable, don't really know what I'm doing with it. I've had a go at using it but the stylus sort of skids across the record into the centre of the turntable. It does play a bit but jumps around alot. Have I set it up oddly or is something dead?
Check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
Posted on Feb 24, 2008
I've been given a Technics sl-bd22d turntable, an Arcam amplifier and a Cambridge 551P pre amplifier. How do I connect them all together?
Depends what type of sockets these have. If the Pre-Amp has a RCA phono sockets you just need some RCA leads. I don't know if the Arcam Amp works with any pre-amp. But if it does, it's likely to have the same type sockets as the others. So you just buy another two RCA leads and connect it up.
Apr 19, 2013 | Audio Players & Recorders
Where can I purchase a Technics SL - B2 turntable belt? John Maxwell
try MCM electronics supply. (MCMelectronics.com) You might have to buy a kit of assorted belts or ten belts. MATelectronics is another supply house.(matelectronics.com) or google SL-B2 turntable belt.
Jul 28, 2010 | Audio Players & Recorders
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
Sep 22, 2009 | Technics SL-1210 Turntable
Had to replace stylus on SL-B2. Arm was "skating" across disc but seem to have that fixed. Sound definitely not correct. What can I adjust?
Hi sounds like the cartridge or stylus are not seated correctly or at correct angle (cartridge).
Also weight/balance and anti skate need adjustment. Try getting the manual and using that to set it up correctly - no easy task though as lotsa info there.... :) Manual for 1200 MK3 will do as well. Hope that helps
Jul 15, 2009 | Technics SL-1210 Turntable
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
What is the best way of cleaning your whole tone arm and hight adjustment on a technics 1200 mk2 as just brought second hand one and works great but very dirty thanks dj fluant-c
Use common sense when cleaning. Don' t use water. Instead I find Windex works well. Just spray enough to loosen up any dirt/grime build up. DO NOT OVERSOAK. And just wipe clean. There really is no real trick to cleaning these things.
Get yourself some cotton swabs, a can of air, and paper towels, and your all set.
- OPTiC
The 1200s Expert
www.1200s.com
Aug 25, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1210 Turntable Logo
391 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
