Question about ViewSonic VA720 17" LCD Flat Panel Monitor
When it powers up the screen is fine then it goes black with no signal box, then if you turn it off and on again screens comes back for few seconds and then off again, sying no signal. Viewsonic LCD monitor VP720b
  • magooo Feb 01, 2010
    Yes, the video card is brand new and it drives the old CRT. I tried regular VGA output and DVI, but it all the same. I get the boot up screen then it goes blank with no signal box on the screen.
    Once I hit the power off and on screen comes back in nice vivid colors but it goes off after few seconds.
    Scholar:
  • 34 Answers
The lcd has three parts the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new
one do go burst! you have to laugh really, what next , a new on/off
button, as you work though the whole inverter !
mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.
Posted on Feb 08, 2010
Testimonial: "Well,the pwr board has caps with mashroom tops, so I bought new board for $21. White at it i will replace input board as well. lamp ok."
    Novelist:
  • 157 Answers
Could the problem be with your computer and not the monitor. Did you try using the monitor with a different computer? Did that work? If so, your video card may be bad in the original machine...
Posted on Feb 01, 2010
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
Iv had an n64 before so i think i have a good idea of how to set it up. i've managed to tune my tv in to find where abouts it is but there's only a black screen.i can turn the n64 off an the tv screen goes...
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position. While the control deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the control deck.
Move your control deck farther away from your TV. If the control deck is too close to the TV, the control deck may cause some interference.
Jan 19, 2011 | Nintendo 64 Console
Screen "blinks" black every few minutes - Dish Network
Hi, Mary with Dish Network Customer Service. When the picture alternately goes from normal to a black screen, it is an indication of an intermitten signal issue. You can attempt to reset the receiver box by unplugging it from the power for 10 seconds and letting it reboot. Hopefully this will resolve your issue.
Jul 31, 2010 | DISH Network 322 DTV Receiver
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
456 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
