Question about Kenmore 64802 Top Freezer Refrigerator
After cleaning my one year old Kenore bottom fridge this afternoon, it has begun making a buzzing noise. It that lasts about 12 seconds and happens about evey 10 minuets.
  • lamccain1 Feb 01, 2010
    The fridge does not have an ice maker. I left the door open for about a n half an hour while cleaning, that was when I first heard the noise.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Appartently your icemaker water has not been turned on or hooked up and the water valve is buzzing . either lift the arm on the icem or pull the wire on the water valve.
Posted on Feb 01, 2010
    President:
  • 1,218 Answers
Good day,
A guess at this time, but I have run across similar problems with a refrigerator that has an ice maker but is not hooked up to water.
In about the same time frame you gave, the ice maker tries to harvest, and the water valve in the back tries to add water and can't. The result being the valve buzzes.
If that's the case, just lift the arm up on the ice maker to stop it.
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
ARS2665AC - Every 3 minutes noise
Unless this is somthing to with the ice maker, it is likely to be the refrigeration pump cycling on and off. It is possible that the pump is being stalled upon start up. Another possibility is that the pump vibrates more as the pressure is being built up and perhaps one of the rubber mountings has worn or perished. As long as the fridge is still working properly as you say then this should not be a cause for concern unless it becomes annoying. Regards
Oct 02, 2007 | Amana ARS2661B Side by Side Refrigerator
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
My jenn air fridge is making a weird buzzing humming noise, lasts about 5 seconds, happens about every 5 minutes or so. The sound is coming from the bottom of the fridge. Any idea why?
Does this have an icemaker and if so is it working correctly? That sounds like the sort of sound an icemaker water solenoid would make. A compressor could make the noise, but not usually that frequently. An icemaker that isn't hooked up but is calling for water may.
Dec 01, 2009 | Dryers
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Maytag fridge stops cooling, then 1-2 days later restarts on own
The buzzing is typically gonna be the compressor trying to start and failing. Am I right in saying the fridge is at least 12 or more years old?
Maytag used to use a compressor made by Tecumseh and they had a problem with starting. They would buzz and sometimes start back up. Sometimes in a few tries or a few days or never. It would continue to re try every couple minutes and last 5-10 seconds.
I would verify if it is a Tecumseh or an Embraco compressor then make your decision.
A service tech should be able to figure this out pretty easily! Normally what I would do is if I go in and it is running then I would turn it off and back on right away. the fridge will go through its restart sequence and typically make its noises then. Hopefully you are not being charged every time they come out
Compressors are the most expensive repair! and on these I always replace the discharge tube since they tend to rot out from sitting in the drain pan.
Let us know what you find!
Feb 21, 2018 | Maytag MFD2561HE Bottom Freezer French...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Jennair JCD2389G side by side
Can you tell where in the unit the buzzing is coming from (top bottom inside outside, etc)? Need a little more information to help.
Dec 04, 2006 | Jenn-Air JCD2389G Side by Side...
Kenmore 64802 Top Freezer Refrigerator Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
