Question about Sony MDR-RF970RK Headphones
Where can i get a replacement rechargeable battery thanks
You can actually use regular AAA nickel metal hydride batteries for these headphones. I have the MDR-RF925R and they are the same way. Just remove the battery back, and cut the label from the original battery pack. You'll need to keep the black plastic case that they fit into. Replace the new batteries into the case, you may want to tape it to hold it together, then you can use the base charger like normal.
Posted on Dec 06, 2010
    Scholar:
  • 74 Answers
You can actually use two regular dry AAA batteries to power these headphones, the only thing is that you will not be able to charge those batteries with the charging station that comes with the headphones.
Posted on Jun 06, 2010
  • stewhi Dec 06, 2010
    You can still use the base charger, you just need to do a little hack. Take the original battery pack from the headphones. Now if you look in the upper right hand corner of the battery box you will see a little gray hook. This is the key, Now just cut the label on the original battery pack and take it apart. You will find that these are two regular old nickel metal hydride AAA batteries. Go to Walmart and pick you up some rechargeable batteries, place them in the same black case and press it together, you may want to use a little tape to keep it all together, then pop them in the battery box and plop it back on the base. It will charge like normal!
  • brian_for937 Aug 28, 2011
    Another issue is the positive end of the plastic battery holder seems just thick enough to prevent contact . The batteries that are in the $29 replacement pack have a slightly longer "nipple". I cut the plastic holder in half and use only the bottom or negative end which is needed to trick the hidden switch. This switch allows the cradle charger to work. If this switch isn't tripped, the red charge light will not come on thus not allowing a charge. Shame on Sony for in effect charging $25 for a piece of plastic which only serves to keep the consumer from using a cheaper and widely available replacement battery!!
Furthur searching on the internet
Posted on Feb 02, 2010
How do you open the Sylvania model no 72032 rechargeable flashlight to replace the battery and light bube?? Thanks
This is from the Sylvania site
  • Dimensions: 2.4" long x 1.7" diameter
  • Light Source: 0.4 watt non-replaceable LED
  • Internal Battery: Sealed Ni-MH 3.6V 110mAH rechargeable battery
This look like it is not replaceable - amazon sells them fairly cheaply
Oct 04, 2014 | Camping, Backpacking & Hiking
My laptop is overheating
The rechargeable battery is at fault and needs to be replaced. This will occur even when the laptop is plugged into an electrical outlet. As, the battery is trying to recharge.
To avoid damage to your laptop, stop using it until the battery is replaced.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Heating & Cooling
THE BACK PIECE FOR THE BATTERY FELL AND I LOST IT WHERE CAN I BUY THE REPLACEMENT
These are the brands and type of AA batteries that you may use in Jazz DV165-BOX.
1. Ni-MH rechargeable battery (Empire and Powerex brand)
2. Ni-Cd rechargeable battery (Sanyo brand)
3. Lithium not rechargeable battery (Energizer E2)
4. Alkaline not rechargeable battery (Energizer brand)
The site where you can see their prices and make order is http://www.batterycanada.com/pro415.asp
Please comeback and give some ratings. Thank you for using Fixya.
Aug 17, 2010 | Jazz DV165-BOX Digital Camera
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
Won't turn on.
call customer service 800-701-5327 they might be willing to replace it even after warranty has expired.
Dec 11, 2008 | Leapster Learning System
Pansonic er200 need new rechargable battery
two AA rechargable batteries can be used, and yes you can replace them yourself.
Dec 05, 2008 | Panasonic ER 240 Beard Trimmer
Dvd player recharger charge status lights blink
The blinking went away as I had charged it for a very long time. However, it was noted that it would not work on the DVD. The battery needs to be replaced. That solved my problem. I still have to look for a new battery for this device: US Logic 680p DVD player with recharging capabilities due to the portability option. It works fine if plugged in, but the battery just needs to be replaced if I want to use it independent of the plug. Thanks for asking how I resolved the issue.
Nov 25, 2008 | US Logic 680P Portable DVD Player with...
Battery life cut down to 7 hours
The thing is, you recharge it too much. Because when you recharge it even though it still has battery power left, it tries to recharge it as much as if the battery was depleted. So, your battery overheats, therefore allowing you 7 hours instead of 20. And yes, it is possible to switch the battery.
Apr 12, 2007 | Samsung YP-T8 Digital Media Player
Sony MDR-RF970RK Headphones Logo
943 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
