Question about Belkin Wireless Keyboard/Optical Mouse f8e832-bndl
I'm not successful in syncing the mouse with the computer
I have been trying to install the wireless travel mouse using the instructions to our laptop. After holding the button on the bottom of the mouse and the USB dongle, the light does not begin to blink faster, just stays on. The mouse then does not work.
I had this problem too!!! I turned off the mouse and then did the button thing!!! I know it say to turn it on first but this is what worked for me! good luck
Posted on Apr 06, 2010
    President:
  • 2,017 Answers
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Posted on Feb 01, 2010
  • 51 Answers
Yes, it worked for me too.
Posted on Sep 01, 2010
Laser mouse very inaccurate?
Instructions
    • 1
      Check your wireless connection. If you are using a wireless adapter or USB linking device, ensure that everything is plugged in properly. The best way to do this is to unplug the device and then plug it back in, making sure everything fits snugly.
    • 2
      Try to re-sync your mouse with your computer/adapter. If your computer came with wireless networking capabilities (such as Bluetooth) and your mouse uses this signal to communicate with the computer, go to your computer's control panel and turn off the network for a few minutes. Then reboot the network and see if the connection to your mouse has been restored. If you are using a wireless adapter, go to the wireless utility that your computer uses to manage the wireless mouse (this can usually be found in the "programs" section) and repeat the above process.
      Look at the bottom of the mouse. If your wireless mouse has a trackball, try removing the cover and cleaning the individual wheels on the inside of the mouse with a Q-tip. If you are using an optical mouse, then try cleaning the bottom of the lens with a soft tissue and a frugal amount of glass cleaner.
    • 4
      Ensure that any drivers needed for the mouse are still installed. Although it is unlikely, the drivers that facilitate communication between your mouse and computer may have been accidentally corrupted or erased. Try visiting the mouse manufacturer's website to download new drivers.
God bless you
May 24, 2013 | HP Wireless Optical Mouse
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
I purchased the belkin wireless mouse, F5L017, it showed me suceffull instalation but no response from the device. Any idea?
If by successful installation you mean that you plugged in the USB dongle and it installed then I would suggest putting in the disc that came with your mouse and going through that installation process to make sure mouse is properly and full installed.
If that doesn't work then I would try to restart the whole computer with the USB dongle attached which will let the computer finish installing the USB driver that was installed when it was first plugged in
Feb 28, 2011 | Micro Innovations Wireless Optical Travel...
Trying to add a wireless travel mouse to my laptop. I installed and can see it in my divice mgr and mouse in my control panel it says that it is working but cannot get the mouse to move my pointer. I...
Some Models of wireless mice have to be synced to the receiver. Look for a button on the receiver and the mouse. Press the button on the receiver and then on the mouse.
Good Luck
Jan 25, 2011 | Computers & Internet
I want to install a Microsoft wireless optical mouse but not sure how to do it.
With the wireless mouse you also have a wireless adapter that is connected via usb to your computer. Insert the usb adapter in an available usb port on your computer. Wait for a few seconds until windows verfies and installs the new device. Then press the sync button located under the wireless adapter and at the same time press the sync button under your mouse.
The mouse will be ready to use.
Regards,
nicolasiac
Feb 09, 2010 | Microsoft Basic Optical Mouse PS 2/USB...
Optical light on Mouse not working
maybe the battery?
follow the steps below to troubleshoot the mouse
Wireless mouse does not respond (generic instructions)
Try to Resynchronize your device with the receiver(connector)
Follow these steps.:
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse at least 6 feet away.
1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
2. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
3. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 3 again.
For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
or
Try different port and restart your computer.
or
Reinsert the batteries or install fresh batteries
If you have the possibility check whether the problem is because of your computer or the device, try the mouse or the keyboard on a different computer.
Sep 06, 2009 | Microsoft Wireless Notebook Optical Mouse...
Belkin wireless travel mouse not connecting to Mac
If you have a usb extension cable try plugging it in so you can place it on a firm surface when you press the sync buttons. Have heard of some issues with activating both mouse and fob buttons at once because of difficulty in reaching the fobs sync button.
Aug 13, 2009 | Belkin F5L017 Mouse
I need to connect my mouse
There should be a tiny sync button on the mouse and the USB receiver that connects to your computer. Make sure your computer is on and loaded, then connect the USB receiver, and make sure the batteries are functional in the mouse. Once it's set up, simply press the sync button on the receiver, then press the sync button on the mouse and wait for it to sync up.
If your wireless adapter is bluetooth, you'll have to install the software that came with your mouse, and use the software to synch the mouse.
May 05, 2009 | Dynex Wireless Optical Mouse
Belkin wireless travel mouse F5L017-USB
if the prob is within two weeks then do the system restore,take the computer to an earlier ti when the mouse was working fine...hope it will work...
Jan 27, 2009 | Micro Innovations Wireless Optical Travel...
Unable to sync Belkin wireless travel mouse
Hate to say this without sounded silly.. but we had these problems, and could not sync mouse with PC. THEN.. I read directions slowly, again.. and figured out.. it is the BOTTOM of the mouse we were not doing. There is a button UNDER the mouse you push.. not the bottons on top. (BOTTOM LEFT side it says). We were clicking the top, bottom of the button. Anyway.. just make sure you turn mouse over. :)
Nov 20, 2008 | Belkin Mini Wireless Optical Mouse...
Belkin Wireless Keyboard/Optical Mouse f8e832-bndl Logo
844 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
