Question about Pride Go Chair Travel Power Chair
Help! 1. My Go Chair battery indicator goes down from full to zero in half a day even with new batteries. Sometimes the indicator shows a full battery (green) but when I turn it off and on again, it shows a low battery (red). 2. My Go Chair has been running smoothly (despite the battery indicator problem) until yesterday. It started to shake whenever I move, especially when I try to turn or reverse. The problem seems to be coming from the left wheel in front. Are these major problems?
  • 2,926 Answers
The wheel shake is a concern, more so than the charging problem.
Your batteries amy not be charging due to a faulty charger, but at this point I can't be sure. I have provided a link http://www.thescooterstore.com/services/ that has contact info regarding repairs to your chair.
Posted on Feb 01, 2010
Why does my chair show a full charge yet after only a half a block it will show only red flashing lite indicating needing charge.
Your batteries are nearing replacement time. They are becoming incapable of holding a full charge.
Apr 28, 2015 | Pride Jazzy Select Elite
How long can i run chair on one charge'
With new, fully charged batteries, you can get a good 8 miles at full speed with a normal weight load on the chair. The chair goes about 4-5 mph, so an hour and a half or more at full speed on level terrain. Be sure to always recharge daily, keep the chair on the charger when not in use(batteries will die if you don't)and avoid running the batteries all the way down....try to stay in the top 2/3 charge range and you will get more life.
Apr 27, 2014 | Pride Jazzy 1103 Ultra Indoor Power...
My Jazzy Select 14XL is having controller issues and I'm waiting for a new controller to come in the mail any day now. But I'm concerned about it fixing everything. There is an issue that I...
Sounds like your batteries have reached the end of their life cycle and are not holding a charge. If the 22NF batteries are more than 2 years old, have them load tested. They probably need to be replaced.
Apr 09, 2012 | Pride Health & Beauty
I have a jet3 ultra that has never been used. In October we bought new batteries. It worked;however, we have not used it or charges it until now. The omnimeter reads 0 and only the one red light shines. ...
amy why did you not keep the batteries charged? even new batteries have to be charged before use. Now plug in the charger and look at the meter with the charger plugged in the meter will show some reading around 4-5 amps. Let the charger work overnight when you get up in the morning fully charged the meter will read zero. Turn on the chair and all the battery lights should be lit. If after charging over night you are still getting one red light then you blew 170.00 and no amount of charging will bring them back. Sorry I wish I had better news. If you replace the batteries charge fully before use and then use the chair some each day and charge nightly for 20 days this will break in the batteries and get them operating at 100%. If you then only use the chair sometimes always put it up fully charged and charge at least once a week If you use the chair for that day charge overnight and it will be ready to use again when you need it. If you are going to leave the chair unattended for 6 months then fully charge the batteries and disconect them from the chair until you need it again New batteries every 6 months can get expensive Hope this helps you
Apr 17, 2011 | Health & Beauty
Have a jet 3 power chair will not take a charge, can't tell that iy is charging
Cathey when you plug in the charger look at the rear of the chair at the meter if the chair is charging then the meter will indicate some amperage reading when it is fully charged the meter will read zero. Also turn on the chair and if the lights are scrolling or flashing it shows that the charger is plugged in. Now if after the meter reads zero (if it ever does) the lights on the joystick should all be lit indicating a full charge. If you aren't getting all the lights and the meter indicated the charger was working then you need to replace the batteries Hope this helps
Mar 24, 2011 | Jet 3 Ultra Power Chair
Unit charges shows full and by mid day in a nursing home battery lights show only 2 red lights. do i need to replace batteries. the chair is a jet3 it was bought in 2003 and not used for about 2...
You definitely need new batteries. There are 2 size U-1 batteries in the chair that will last between 1.5 and 2 years. Get the deep cycle sealed gel lead acid batteries, preferably AGM. Hope this helps.
Feb 15, 2011 | Jet 3 Ultra Power Chair
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
Battery doesn't charge
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair has not been charged in a while or has been stored. Having the chair on or off while charging will not affect the charging process, but you ususally want it to be OFF.
Mar 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Power problem
Seeing as you notice that your battery life is half, this most likely means your battery is no longer able to hold a charge, or a full charge. It could also mean the battery is defective.
If your laptop is still under warranty, the manufacturer may replace it. If not, you'll have to buy a new battery, unless you always keep it plugged in anyways.
Mar 23, 2009 | Dell Inspiron 600M Notebook
V262 constantly beeps "low battery" alert
your battery might need to be changed. even if it has a full charger it might not be able to properly charge you phone.
try a new battery.
Mar 06, 2008 | Motorola Mobility V262
Pride Go Chair Travel Power Chair Logo
111 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
