Question about One For All URC-3021 Remote Control
I need the code for the urc-3021 for a zenith tv
Codes
  • 2,335 Answers
I can help you with your URC-3021 Universal Remote Control issues.
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the Urc-3021 Code List?
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
One For All URC-3021 Code Entry
Urc-3021 Code List Download
Posted on Apr 24, 2010
Sparky-UK
  • 129 Answers
SOURCE: Need Code for Proscan TV for my URC-3021 All in one remote
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3021
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Posted on Jan 07, 2008
  • 217 Answers
SOURCE: NEED CODE FOR URC-3021 TO PROGRAM APEX TV
http://www.ofausa.com/list_codes.php?db_value=expert4&remote_choice=URC 3021
just scroll down the tv section
Posted on Jun 27, 2008
ButtFuzz
  • 463 Answers
SOURCE: urc-3021B00 need codes for Symphonic tv
If you have the owner's manual for the remote, try the codes under "sylvania" or "Funai"
Posted on Feb 27, 2009
  • 64 Answers
SOURCE: need code for zenith on urc-3220
016,017,092,000,[COMBO--000,037] are the codes
for your Zenith TV. Follow these instructions
carefully. These are as close as i can get you
to getting you operations...the rest is up to
you. GOOD LUCK!
  1. PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER the 3 digit code for your brand.
  4. You should receive 2 quick flashes after entering your code.
  5. PRESS the POWER button to test the code.
If you have tried all of the set-up codes for your brand of equipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
  1. PRESS the button for device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
Blinking Back the Code:
  1. PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
  3. PRESS 9 - 9 - 0.
  4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
  5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
  6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
Posted on Sep 12, 2009
pabloloco
  • 2335 Answers
SOURCE: URC-3021 Remote Control: I need the codes for tv's....
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the One For All URC-3021 Code List?
I hope that helps.
One For All URC-3021 Manual
One For All URC-3021 Reassign Key
Posted on May 29, 2010
I need set up for this remote and my zenith tv
Hello
Setup codes for Zenith TV with URC-3021 remote control are:
0017, 0463, 0178, 0092
OK.
Jul 27, 2011 | One For All URC-3021 Remote Control
Need all in one remote urc3021 code for dynex tv
Do you mean a One For All URC-3021 remote? The manual and code lists are available here: http://www.oneforall.com/support/manual . Enter Universal Remote and then the model in the drop down menus. The direct link for the URC-3021 manual is http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
The Dynex TVs are usually made by LG/Zenith. You can try the Zenith codes: 0017, 0463, 0178, 0092 .
However, universal remotes are usually limited to having only codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote.
I hope this helps.
(the URC-3021 remote manual has a 2004 copyright date.)
Jun 28, 2011 | One For All URC-3021 Remote Control
I need the codes for an RCA and Emerson TV
The codes for RCA TV's are: 0047, 1047, 1147, 1247, 1347, 1447, & 1547.
The codes for Emerson TV's are: 0154, 0236, 0463, 0180, 0178, 0171, & 0623.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
Apr 19, 2010 | One For All URC-3021 Remote Control
What is the code for a Zenith Tv
The codes for Zenith TV's are: 0017, 0463, 0178, & 0092.
I hope that helps.
Mar 03, 2010 | One For All URC-3021 Remote Control
I need codes for my one for all urc-3021 for an apex digital converter box and a zenith tv
I do not see a listing for an Apex digital converter box in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes.
Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
Mar 01, 2010 | One For All URC-3021 Remote Control
Whats the code for a zennith useing a oneforall remote control?
I hope that helps.
Jan 29, 2010 | One For All URC-3021 Remote Control
Zenith code
I hope that helps.
Jan 18, 2010 | One For All URC-3021 Remote Control
All for one universal remote with no codes for a Zenith TV
The link below will take you to a page on the One For All website where you can enter the model number of your remote and receive Zenith TV codes and instructions on how to use them.
http://www.oneforall.com/en_UK/support
There are so many models of One For All remote controls, I cannot give you codes and instructions for all of them.
If you have a URC-3021, then the Zenith TV codes are 0017, 0463, 0178, 0092.
Sep 20, 2009 | One For All URC-3021 Remote Control
I just need a code for my TV. It is a Zenith
I've found 4 codes for Zenith tv's:
0017
0463
0178
0092
If none of these work you can use the remote's search mode, for more info here is the manual:
http://www.solidsignal.com/manuals/URC-3021%20Remote.pdf
I hope this helps
Mike
Jun 17, 2009 | One For All URC-3021 Remote Control
Codes for an zenith tv
Don't know if you've found what you're looking for yet. If not, follow this link and hust enter your remote #, device manufacturer, and device and you'll be hooked up. If this is what you were looking for PLEASE rate this as fixed. If you need more help just add a comment and I'll be glad to help. Later koolbro. http://www.ofausa.com/advanced_search.php
Apr 23, 2008 | One For All URC-3021 Remote Control
One For All URC-3021 Remote Control Logo
150 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
