Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Soap dispenser still has the soap in it after the dishwasher cycle has ended...
The soap is not dispensed when the dishwasher is running. Also, sometimes the dispenser door does not open (we have checked to be sure nothing was blocking it). As an experiment, we have also tried running the dishwasher with the soap dispenser open, and the soap is still there at the end of the cycle. Help!
  • Anonymous Feb 29, 2008
    Hi. I have the same problem as Bob. Can anyone suggest a solution
Do you have a salt unit fitted. I had the same problem and the repair guy had to replace the salt unit as it was blocked up. Failing that it might be the board not opening the solenoid to allow the water to be jetted through the soap dispenser.
Posted on Mar 16, 2008
    Sergeant:
  • 351 Answers
Loading problem is the spray arm spinning also only use one teaspoon of soap the basket could also be hitting the arm
Posted on Mar 02, 2008
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Elite soap door problem
Dispenser may be bad. Push the hi-temp button , air -dry, hi-temp, air-dry in that order. All lights will lite up and this will do test cycle of all components. If soap disp opens then soap tab may be the issue. I have had intermittent dispenser issues and they are often hard to solve as other components may be at fault.
Nov 28, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap cup still has soap at end of cycle, but cup is open
heatman101
Nov 25, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Soap left in dispenser
Hi Vneck,
I'm Harvey the Master Plumber.
Your problem is: When you run a cycle, there is soap left in the dispenser at the end of the run.
Do you use a powdered soap? This can be a problem for some d/w. Sometimes it occurs as a d/w gets older. Try a liquid d/w soap. Make sure it says "dishwasher" on it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 21, 2008 | Dishwashers
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
1,312 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
